Question about Venturer Televison & Video
The TV has no audio. I have a Venturer PLT37260 and I just connect it to the cable box and it has no audio. I have tried everything but I have not been able to fix the problem
  • Martha Bustillo Apr 05, 2011
    I have no audio on my TV set. I have checked the setup, checked the connections. Had the cable company check the cable box and have not been able to fix it. I have a Venturer PLT37260
  • 325 Answers
The model number you have given me is for the remote to the tv? There is a small circuit board responsible for the sound on the tv. This is considered the mainboard. I've also seen some tvs where the board is independent of the mainboard and is next to the IR receiver on the television. If you're sure you have checked all the settings then I would begin to look internally. I would look for the speaker wires and trace them to their source and begin a repair of the sound part of your television.
Hope this helps! Please rate!
Posted on Apr 05, 2011
    President:
  • 2,080 Answers
The most common causes for no sound are as follows:
Volume turned down too low.
MUTE button on.
Speakers set to OFF in AUDIO OPTIONS MENU.
MTS set to SAP in AUDIO OPTIONS menu instead of STEREO or MONO.
Headphones plugged into the headphone output jack on your tv.
If it is not a simple button / setting problem like the ones listed above, make sure the problem is present on all channels and all input modes like the DVD as well. If it is, then the problem is likely a component failure on one of the circuit boards inside the set. If your warranty is still valid, then you should return it right away to the place of purchase for a refund or exchange.
Otherwise, this will require significant disassembly, troubleshooting, repair and component replacement by someone with at least some basic electronic and electrical safety skills. If you are unable to conduct these types of procedures yourself, then you will have to seriously weigh the cost benefit of spending at least $100-$200 to get it fixed at a repair shop by a technician, versus the price of a brand new TV which comes with a full warranty.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck, hope this helps a bit.
Joe.
  • 1 more comment
  • Joe2
    Joe2 Apr 05, 2011
    You probably have this already but here is a link to the Owner's manual for that model:
    http://www.managemylife.com/mmh/owner_ma...
    To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
    You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
    See page 19 of the ONLINE USER'S MANUAL for detailed instructions on how to set up the AUDIO OPTIONS on your set.
    Good luck.
    Joe.
  • Joe2
    Joe2 Apr 05, 2011
    If you are able, try testing the AUDIO OUT jacks at the rear of the set to see if they still work.
    Use a set of red and white (left and right0 RCA cables to connect the AUDIO OUT of your TV to the AUX IN of a home stereo receiver / amplifier.
    Then turn on the tv and check if you can hear the TV program sound coming through the stereo speakers when the stereo is also turned on, turned up, and set to AUX input mode.
    Good luck.
    Joe.
  • catadelrosar
    catadelrosar Aug 06, 2012
    Hi, I have the same problem. My venturer not produce sound. The strangest thing is that when I try to change the MTS "mono" to "stereo", I cannot do it. The menu does not give me the option. I have a venuter PLV3622 22" . Thank you.
Setting up Panasonic SC-HT930 to Cable Box & TV
I am glad to assist you fully. I need the complete model of the TV and i will be able to tell you exactly how to hook it up. What connection/cable are you using from the cable box?
Thanks,
Lee
Jul 04, 2008 | Panasonic SC-HT930 System
My 19" Venturer TV will not turn on
  • 1 Check the antenna. Adjust it to see if the picture improves. Confirm that the antenna cable is firmly connected. Check to see that input cables are connected.
  • 2 Scroll through the channels to determine if the problem is specific to a station. Check any video sources (i.e. cable box). Make sure all cables are connected tightly.
  • 3 Check for interference. Power off all nearby devices one by one to see if any of them are creating the lines.
  • 4 Power off the TV for 30 minutes before turning it back on.
  • Mercedes Superchargers
    Jun 13, 2012 | Venturer 19 Class 720p LED LCD TV w/ DVD
    No signal on tv
    What are you using as your source of RF. Connection from a Cable TV supplier? - if so Cable TV is all delegated to use their box.
    Off air digital antenna?
    - if so maybe you need to set your TV to the 'off air'
    May 24, 2012 | Venturer PLV31220S1 22 in. LCD TV
    Conection to tv problem
    gerardali,The question is what input connection do you have on your TV?
    Your Venturer has three types of video outputs:
    1) Composite video (single yellow RCA)
    2) S-video (single 5 pin cable)
    3) Component (3 cables-red, green & blue RCA's).
    The component will give the best picture but not all TV's have this connection. The second best is the s-Video but again not all TV's have this connection either. The composite is the lowest quality and the most common available connection.
    Make sure that you are using the same audio and video inputs on your TV; such as, if your audio is going in AUX 2, make sure your video connection of choice is going into AUX 2 also.
    -Chris
    Mar 21, 2010 | Venturer STS152 System
    Sony PCM 48 Issue
    As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
    Jun 17, 2009 | Sony STR-DE698 Receiver
    Need to remove base from Venturer 26'' LCD TV
    look on the tv above where the base slides into the tv and you will see screws. unscrew those screws and lift the tv off of the base.
    please mark my answer as a fixya!
    Mar 08, 2009 | Televison & Video
    Wiring problems
    Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
    For video:
    All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
    • Video out from cable, HT, and combo player.
    • Video in to TV. Your choice of inputs.
    For audio:
    Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
    • Audio out from cable box and combo player.
    • Audio in to HT.
    The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
    Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
    Am setting up a bose GSX 3-2-1 home theater
    simplist solution, if the TV has an audio output just run that to the Bose system.
    what type of TV are you connecting to?
    Is the cable box an HD or digital box?
    Jun 23, 2008 | Bose Cinemate Digital Home Theater System...
    Venturer AVR2000, home theatre system
    I have same system and had same problem until I connected digital audio coax to receiver from digital source.(orange port). Also try making the center front speaker much louder volume setting than all other speakers. hope it helps.
    Jan 27, 2008 | Venturer (1012827) System
    Televison & Video Logo
    754 people viewed this question
    Top Venturer Televison & Video Experts
    john milligan
    Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
