Question about Ariston Technologies Washing Machines
TtI live in Belize but brought my Ariston Margherita A1324 with me from the UK. Local repairmen know nothing about front-loading 220v automatic wahing machines, so I cannot find out what parts need replacing to fix the problem. The program knob just keeps clicking round when I try to start the machine. Any suggestions?
  • westward_372 Apr 09, 2011
    It sounds good to me, but what do I know? My 'repairman' is coming out on Tuesday, so I will show him your suggestions. Things like wrong hose height are not the problem, as the machine has been working fine - it just suddenly stopped accepting any programming. I'll get him to try the connectivity tests that you suggest to try to isolate where the fault may be occurring, as I don't want to end up buying so many parts for the machine that it is not worth repairing, but on the other hand it is a far superior machine to the American style rubbish that is available out here - huge drums, massive running costs - typical of the Yanks! I think most of the parts are still available in the UK, so I'm not going to give up on it too early. Watch this space...... Thankyou for the suggestions, anyway!
  • Ariston Tech... Master
  • 19,396 Answers
Hi.
The problem can be a defective timer control, but before replacing timer all the other parts must be tested. Timer is expensive and it is not easy to be tested directly.
Tell the technician to:
1) Open the control panel held by screws and look for the sealed envelope with the diagnostic tech sheet. If the tech sheet is in there you can run a diagnostic.
2) Check height and setting of the drain hose at the back to ensure that there is no siphoning because of hose incorrect elbow height (water will go back inside the tub and cause machine jamming if the hose is not set at the correct height specified in the manual- which is from 60 to 100 cm).See: MARGHERITA
3) Check drain and empty water from tub. Access the hose connected to drain pump (at the bottom of the washer), remove blockage and empty water).
4) Check inlet (this is the same as older machines). Check that inlet valve is opening, test valve using an Ohm meter to ensure that the solenoid inside the valve has continuity (low Ohms no infinity).
5) Test or replace the pressure switch. The part is tested reading Ohms on switch contacts with tub empty and full.
If the technician still does not find a problem after testing all that, then the timer may be defective. A definitive test on the timer is done reading voltages while machine cycle is on.
Regards.
Ginko.
Posted on Apr 06, 2011
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Mar 25, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
