Question about Brother Office Equipment & Supplies
A few keys + line spacer does not respond on the 1st strike
  • Brother Master
  • 3,594 Answers
Under each key is a foam contact pad. They get dry and crumble. The keyboard needs rebuilt.
DickyO
Posted on Apr 05, 2011
How to place the main bearing shaft support back into Muncie 4 speed transmission
Here's what Chilton has to say on assembling the main shaft.
1.assemble 2nd gear, from rear of main shaft, with hub toward rear.
2.Install 1-2 synchronizer ring , with clutch taper to rear, together with a blocker ring on each side so their keyways line up with the clutch keys. Some units will have a snap ring to go on now or some units will have a 1st gear spacer sleeve to go on.
3. Install 1st gear with hub toward front and 1st gear thrust washer.
4.Press rear main bearing onto shaft being sure to seat it firmly. The diagram shows a piece of 1 and 5/8 ID pipe used to do this.
5. Install correct snap ring in groove on mainshaft behind rear bearing. Max gap between snap ring and rear face of bearing is 0"-.005".
6.Install 3rd gear, hub to front, and synchronizing ring, notches to front.
7. Install 3-4 clutch assembly with taper and hub to front. Make sure keys in hub correspond to notches in 3rd gear synchronizer.
8.Install snap ring on mainshaft with ends of snap ring behind spline teeth.
9.Install rear bearing retainer. Spread snap ring in plate to allow plate to drop around main bearing and press on end of mainshaft until snap ring engages groove on bearing.
10. Install reverse gear with collar to rear.
11. Press speedometer gear drive on mainshaft. From the inside face of the speedometer drive to the inside face of the rear bearing retainer should be 4 and 5/16".
Sep 15, 2013 | Cars & Trucks
Lamp failure in WD-52525
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Help me down load the game counter strike
If you want to download counter strike 1st thing you do is go to google.com then type utorrent then download and installed it after you install go to www.kickasstorrents.com then search counter strike.. Then download it then its done just wait ti finished it then install.. Happy gaming.. I hope it will helps you
Jul 11, 2011 | Electronic Arts Counter-Strike: Source for...
The Yale lock on my Front door in becoming increasingly difficult to open with the right key. I'm worrie dthat one day soon I wont beable to open it at all. What is wrong with the lock? Could I use...
Yes I would useWD-40 to spray in lock. Insert key part way in lock and spray a small amount on key and into lockset if tou can, If you can fit spray nozzle into keyhole ,and spray liberally. You can also use dry graphite to lube lock mechanism. I would check to make sure that your keys aren't bent or worn to the point that I hope this helps you. Thanks they can't engage all tumblers inside lockset. I would also make sure that latch on lock is lining up with strike plate in door frame. One easy way to do this is to use a felt tip marker to cover strike plate on door frame and open and close door several times. Where ink from marker is rubbed off will show you where latch is contacting strike plate. If it is out of aligmment this will make it harder to open or lock with key. If necessary adjust strike plate for better fit. I hope this helps you. Thanks
Nov 17, 2010 | Garden
Front brake rotor on 1992 Ford Ranger 4wd with auto lock in
With Automatic Locking Hubs
  1. Raise the vehicle and install safety stands.
  2. Remove the wheel lugnuts and the wheel and tire assembly.
  3. Remove the retainer washers from the lugnut studs. Remove the automatic locking hub assembly from the spindle.
  4. Remove the snap ring from the end of the spindle shaft.
  5. Remove the axle shaft spacer
  6. Being careful not to damage the plastic moving cam or thrust spacers, pull cam assembly off the wheel bearing adjusting nut and remove the two plastic thrust spacers from the adjusting nut. CAUTION: Do not pry on the plastic cam or thrust spacers during removal. Prying may damage the cam or spacers.
  7. Using a magnet, remove the locking key. NOTE: If required, rotate the adjusting nut slightly to relieve pressure against the locking key, before the key can be removed. CAUTION: To prevent damage to the spindle threads, look into the spindle keyway under the adjusting nut and remove the separate locking key before removing the adjusting nut.
  8. Loosen the wheel bearing adjusting nut from the spindle using a 2-3/8 inch Hex Locknut Wrench T70T-4252-B or equivalent.
  9. While rotating the hub and rotor assembly, tighten the wheel bearing adjusting nut to 47 Nm (35 ft lb) to seat the bearings. Spin the rotor and back off the nut one-quarter turn (90 degrees).
  10. Retighten the adjusting nut to 1.8 Nm (16 in lb) using a torque wrench.
  11. Align the closest lug in the wheel bearing adjusting nut with the center of the spindle keyway slot. Advance the nut to the next lug if required. Install the separate locking key in the spindle keyway under the adjusting nut. WARNING: Extreme care must be taken when aligning the spindle nut adjustment lug with the center of the spindle keyway slot to prevent damage to the separate locking key. The wheel and tire assembly may come off while the vehicle is in motion if the key is damaged.
  12. Install the two thrust spacers and push or press the cam assembly onto the locknut by lining up the key in the fixed cam with the spindle keyway. CAUTION: Extreme care must be taken when aligning the fixed cam key with the spindle keyway to prevent damage to the fixed cam.
  13. Install the axle shaft spacer.
  14. Clip the snap ring onto the end of the spindle shaft.
  15. Install the automatic locking hub assembly over the spindle by lining up the three hub assembly legs with three pockets in cam assembly. Install the retainer washers.
  16. Install the wheel and tire assembly. Install and tighten lugnuts to 135 Nm (100 ft lb).
  17. Make sure the final end play of the wheel on the spindle is 0.00-0.08 mm (0.000-0.003 inch). the maximum torque to rotate the hub is 2.8 Nm (25 in lb).
Jul 27, 2009 | 1992 Ford Ranger
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
Keyboard responds intermitantly
under each key there is a plastic type small button with a rubber mounted on it if it is moved from its position slightly this happens.need to get opened and cleaned and readjusted properly to make it work properly. feel free for further assistance. thanks.
Jan 04, 2009 | HP Pavilion dv6000z Notebook
59 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
