Question about Noblex PRO 150 EII Medium Format Camera
Noblex Pro 60/150 film overlapping
I bought a used Noblex Pro 60/150 E recently. My first roll of film has bad overlapping problem. The frames overlap one another by as much as 5 mm (quite consistently throughout). Wonder how to fix this. According to manual, there should be a spacing of 3 mm.
Just got mine as well! Awesome! mine also overlapped but it is simply a film loading issue. Make certain the film is loaded with the winding nob in the "S" position when the arrow on the film aligns with the red dot. Wind on to shot 1 and it will click and stop. All shots should then line up.
Another tip - take images 1 and 2 of the same pic at the same exposure of the exact same scene. Assuming the rest of the images are taken with the same lighting situation over the next hour or so your local lab should be able to clip test image 1, then process the remainder of the film ("push" or "pull") to give 5 remaining images exposed spot on!!
Cheers from Ralph!
Posted on Apr 29, 2009
Some frames on film are partially overlaped
After you remove the bottom cover on these, there is a steel plate. Under the plate is a phase switch which needs to be cleaned. You have to de-solder several flex circuits to get the plate off, and when the plate is removed there is a loose spring (if memory serves me correctly, I haven't done one of these in years).
Also, the black button you push to free the flash has lips on the inside that have a strong spring attached, and the lips break off. They can fall into the gearing on the bottom
Mar 16, 2014 | Pentax MZ-50 35mm SLR Camera
Am having trouble loading my Noblex Pro 150E2. Haven't used it in years...is the right hand compartment for the empty film spool supposed to spring load also? Mine isn't and I cannot get the rigid empty...
Does the wind handle lift up like a 35mm camera? Or, some cameras you can just push the bottom end of the spool down and release the top end of the spool.
Apr 28, 2011 | Noblex PRO 150 UX Medium Format Camera
How many winding clicks should i use for a holga using 35mm ?ive heard 36-24 ?which is one is correct?
Same as you use for 120mm, since the size of the image projected by the camera doesn't change by using thinner film. If you wind it less, your frames will overlap quite a bit.
Feb 27, 2011 | Holga 120CFN Film Camera
The picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Nov 22, 2010 | Vizio VF550M 55 in. LCD HDTV
Hello, i have dell vostro 1014 . i have installed windows xp pro. Sp3. but my wi-fi is not runing on my laptop. so pls tell me which wi-fi is suitable for my laptop. Thanks, sunil saxena
The question is too general sunil.
you might have to enable wireless function wit a hotkey sequence--mine is Fn-F2--but most pc's are different
goto manufacturers site/manual and find out if you have this keyboard function.
there are available to the consumer,gereralising 6 wi-fi protocols commonly in use ,thats 802.11 a/b/g/n/i/x-----n/ is the most recent.
they have between 11 and 14 channels depending on which country you are in (excluding Korea)
channel 1,channel6,and channel 11 are the best channels to choose because they dont overlap,the width of these channels is 22mhz ,all the other channels overlap.
bluetooth uses a similar channel system and can come into conflict with 802.11 also it can suffer interference from other household goods like microwave ovens.
the signal is sent out repeatedly in "frames" whic can be encrypted by one of the encryption standards but is also prone to be "dropped" in which case the code on modern machines re-sends the "handshake" repeatedly.
Sep 15, 2010 | Dell Computers & Internet
Problems with single exposure on Noblex 60/150E
You would have to send it in for repair to Noblex Canada.
Email: noblexcanada@shaw.ca for more and complete infirmation.
Thanks, Siggi
Mar 16, 2017 | Noblex PRO 150 EII Medium Format Camera
OVerlapping frames
This is due to a poorly manufactured and designed camera: it IS a Holga, after all...
What's happening is that the film advance is allowing the film backing paper (which has the numbers printed on) to slip relative to the film. All you can do is to learn when to compensate by advancing the film a little more than the numbers indicate.
Given that most Holgas are only designed to last for around ten to twelve rolls of film (they can last far longer though), you might not have to put up with the fault for much longer.
May 14, 2010 | Holga 120SF Medium Format Camera
Picture is curved and wording is overlaping on my Sony 65'' hd pro
convergece ic's are bad also check low value resistors on convergence board. not an easy repair. you need expert soldering experience.
Feb 25, 2009 | Televison & Video
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Film not advancing fully
Are you sure that you have loaded the film properly?
Sometimes if you have not started the film so that the sprocket pulls the film correctly the film can aquire slack and the teeth of the sprocket may not be successfully pulling the film from the canister each time.
Sep 07, 2007 | Pentax ZX-50 35mm SLR Camera
Noblex PRO 150 EII Medium Format Camera Logo
322 people viewed this question
Top Noblex Photography Experts
pontelemon
pontelemon
Are you a Noblex Photography Expert? Answer questions, earn points and help others
