OKI C5510 MFP - slow flashing green on left; quick flashing red on right - unplugged memory card and reinserted-no help; replaced 4 fuses on ink drums-no help
  • 1 more comment
  • tim1218 Apr 05, 2011
    this model has a scanner/document feeder mounted above the printer-the message window is on the scanner (top) portion. the ethernet cable feeds to the scanner as well. there is a usb connection from scanner to printer therefore when I disconnect the printer cable there is no communication between printer and scanner therefore no message to read on scanner window
    I cannot get OKI USER to display
    there is no paper jam. i have had the ink cartridges/drum units and heater element in out a dozen times or more. also - the paper jam light is not flashing. the triangle with exclamation point is the red light taht's flashing as i said in my original question
    Guru:
  • 1,833 Answers
Problem in posting. Will reply soon.
Posted on Apr 06, 2011
  • Aloke Das Apr 06, 2011
    According to your problem first check if there is any paper jam. Clear the jam. Change the toner and clear the cartridge. You can also try to change the power cable. Finally you can reset the system. After reset reboot the printer.
    Genius:
  • 1,570 Answers
Try this hard reset
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply. Wait for a couple of minutes.
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Posted on Apr 05, 2011
  • Benjamin Jr Singson Apr 05, 2011
    Hi Try to reset the toner drum counter
    1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
    2. Menu window will show "OKI USER"
    3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
    4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
    5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
    6. Window shows "NV-Ram- Initial Table 1".
    7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
    8. Restart printer.
    If MENU windows show up. Try to find whether there are paper jammed that cause lights to blink. Normally a paper jammed is one causes of warning lights.
    What did you do before? Are you printing before and stops prints and it warning light are blinking? If yes, I believe it is a paper jammed message and need to clear the paper jammed.
    Here is how to find the paper jammed.
    http://www.okisysthai.com/support/printe...
    I hope it solves your problem. Regards
Oki C5350 error 563
563 I usually drum code reset, some OKI machine have sensors in the side frames they look like a little round window, clean with Q tip, I will assume you have replaced the drum, right?
May 05, 2014 | OKI C5510 MFP All-In-One Led Printer
Oki C5510 'Unable to detect printer'
If you have all the led's lit and they are not flashing it means the printer is in download mode. In other words its waiting for you to download new firmware. Look at OKI's site and find the firmware and follow the instructions. That's why you cant install drivers because the printer no longer knows what it is!
Jun 17, 2017 | OKI C5510 MFP All-In-One Led Printer
How do I fix parameter or argument error
In addition to ensuring that the mail server is set to relay email for the OKI MFP, you also need to go to the Send Mail configuration page and ensure that a From address is set (even if you have already inserted a default from address in the Mail Server configuration page).
Dec 30, 2009 | OKI C5510 MFP All-In-One Led Printer
Is there a Windows 7 driver for a OKI C5510 MFP?
No not as yet i think there still having problems with vista drivers.
Nov 23, 2009 | OKI C5510 MFP All-In-One Led Printer
Computer cannot see Oki c5510 in network.
It's very possible that with a reboot of the printer and/or your router that DHCP assined a new IP address to the machine. Look in your router settings for the active clients and look for the IP address of the printer. Than go into your printer management within Windows, check the IP address assigned to the printer and change it to match the IP address you found on the router. It's happened to me before and it can be very frustrating.
Aug 08, 2009 | OKI C5510 MFP All-In-One Led Printer
OKI C5510 - when printing on photo paper, makes goo all over and photo does not print properly??
you must choose the thickest media type possible at the printer and on the pc. your fuser is not fusing properly causing toner to goo on the roller, changing to thick paper increases temp and slows printing to ensure bonding. some coated papers do not work well with OKI printers. you should check mnf website for specs and recommended papers types
Aug 04, 2009 | OKI C5510 MFP All-In-One Led Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
How to reset toner drum for the oki c5510 mfp?
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | OKI C5510 MFP All-In-One Led Printer
jasbo
jasbo
