Question about Bosch SHI6805 Dishwasher
Bosch SHI6805 Dishwasher leaves residue; how to prevent and how to clean drain
  • tedhalaby Apr 05, 2011
    JUST ADDING VINEGAR DOESN'T HELP; SHOULD i USE RINSE; ANYONE OTHER SUGGESTION
    don't have voltmeter...how else?
  • Bosch Master
  • 1,902 Answers
Hello & Welcome to FixYa
As the water did not drain completely and leaved residue on the dishes then check the drain hose & drain pump filter for any clogs/obstructions, if you have already cleaned these parts after taking out the bottom of the unit and the unit will not work then replacing the float switch assembly which is located at the bottom inside of the unit is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Apr 05, 2011
  • 4,323 Answers
Hi
The issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling and/or draining ability. Use your voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If your switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott Apr 05, 2011
    Please read it completely....if you dont have voltmeter then run the dishwasher with vinegar at its hottest temperature setting....run a full cycle and then take out the bottom front panel and clean the drain pump assembly if the issue is not solved then you will have to replace the float switch
  • 5,081 Answers
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Bosch SHI6805 Dishwasher leaves residue on dishes
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 05, 2011 | Bosch SHI6805 Dishwasher
My Bosch dishwasher is streaking the glassware, inside of the dishwasher and plastic utensils for the past couple of months. What is wrong?
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 14, 2011 | Bosch Dishwashers
Dirty dishes & not draining properly
Feb 11, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
Water not entering shi6800 all plumbing fine to machine
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Jan 06, 2011 | Bosch SHI6805 Dishwasher
Water not draining properly - leaving residue in bottom
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Aug 17, 2010 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. I have put through a dishwasher cleaning...
Hi shanandpop
I'm Harvey the Master Plumber.
Your question is: Your Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. You have put through a dishwasher cleaning solution, but find it isn't doing anything to resolve the problem?
You're still under warranty. The best advice is to use it. If it is not fixed the first time out, demand a new one from where you bought it. Sometimes they drag this out till the warranty runs out, then where will we be.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Bosch Dishwashers
Bosch dishwasher leaving residue
You either need a water valve, if the dishwasher isn't filling with enough water, or you need to run a dishwasher cleaner through it.
Apr 07, 2008 | Dishwashers
Bosch SHI6805 Dishwasher Logo
197 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
