Question about Apple iPhone Smartphone
Where do i insert sim card on the 3g iphone - Apple iPhone Smartphone
  • 449 Answers
On the top of the iPhone 3G is the sim carrier with a small hole. There is a tool in the iPhone 3G box which you can push in that hole top pop out the SIM card sled.
You can also use a straightened paperclip to push into that hole.
When you press down in that hole, the sled pops up and you can pull out the SIM card.
Posted on Apr 05, 2011
Sim card for iphone 3g?
Yes, provided the iPhone 3G is not locked with any other different network. If it is then, you need to unlock the iPhone.To unlock an iPhone the remote unlock service would be a better option because, you need not give your mobile to someone else nor do you have any chance to enter the wrong unlock codes. To get such an unlocking service for your iPhone 3G approach Wickedunlock.com and by submitting the country and network to which the mobile is locked to you will be able to remove the restriction from the respective network. This will be a permanent unlocking solution. Once unlocked you can swap networks.The iPhone 3G supports Mini sim...and hence insert the respective sim size.
Apr 28, 2014 | Apple iPhone 3G
Insert sim card into 3g iphone
iPhones use a Mini Sim and you open the door with a paper clip folder out or similar object. The slot is on the outside and you will see a small hole where the paper clip can be inserted.Regular size sims will NOT fit in.
Jan 18, 2012 | Apple iPhone 3G
I have 3g iphone.i take this from New York to BKK. In NW, it can make phone call when i insert sim card. In BKK, it doesnot work when i insert thailand sim card. Please,tell me how should i slove that...
Probably iphone is Sim locked in U.S like in here. So to solve it you need to jailbreak and unlock it, this is nothing very hard but you need to know current software version of your phone. And it takes some time...
Here is a link where they give you step by step guide, i wont write it here because they have the download links there:
http://thetechjournal.com/electronics/iphone/jailbreak-unlock-iphone-3g-with-3-1-3-ios-4-0-keep-3g-data.xhtml
Jun 10, 2011 | Apple iPhone 3G Black Smartphone
How to insert sim card in iphone 3g
Turn off your iPhone 3G and make sure any cords or connector cables are removed from the device. Then, hold your iPhone 3G upright.
  • Locate the Sleep/Wake button and headphone jack on the very top of the iPhone. Between these two components you will see a very small hole.
  • Insert the tip of a paper clip into the hole to release the iPhone's SIM card tray. The small tray will pop up relatively quickly from the top of the iPhone. If there is already a SIM card in the tray, use your fingers to remove it.
  • Insert the SIM card you want to install into the phone facedown in the tray. Make sure the side without the reflecting panel is inserted first.
  • Press the SIM card tray gently back into the slot until you hear it "click" into place. Now turn your iPhone on. All of the information on the card will now be in your iPhone 3G.
  • Mar 16, 2011 | Apple Computers & Internet
    I DONOT HAV SIM CARD RIGHT NOW SO IT WILL NOT SHOW ANY THING UNTILL I INSERT SIM
    Until you insert in a valid sim for the iPhone 3G it will not activate. If you want to, you can jailbreak & unlock the phone to give you access to the phone without a valid sim. Greenpois0n and PwnageTool are two examples of tools that you can use to jailbreak/unlock your iPhone 3G.
    Mar 01, 2011 | Apple iPhone 3G
    How to insert sim card in iphone 4
    Kindly check the link below for step-by-step instructions on inserting SIM card in to an iPhone 4:
    http://webtrickz.com/how-to-insert-sim-card-in-iphone-4/
    Thank you and good luck!
    Oct 20, 2010 | Apple iPhone 3G
    How to insert sim card 3G
    To insert the SIM card into the iPhone 3G you first have to remove the SIM tray from the top of the phone, located near the power button. Use the SIM tray removal tool that came with the phone, or alternatively a paperclip. Push into the small hole and gently pull the paperclip back out the hole, the tray will come with it. Insert your SIM into the tray the correct way round and put the tray with SIM back into the slot. Hope this helps!
    Aug 06, 2010 | Apple iPhone Smartphone
    How to insert sim card in i phone 3g
    This is how you insert a sim in iphone 3g
    There is a little hole along the top of the iphone, stick a paper click in and it ejects a tray to put your sime in.
    It's not electric, so you need to give it a push
    May 19, 2010 | Apple iPhone 3G
    How do you open the iphone to insert SIM card?
    You can not open the iphone to insert a SIM card. There is a slot at the bottom of the iPhone and the SIM card goes in there. When you purchased the phone you should also have recieved a special gadget that you actually push into the bottom of the phone so that you can remove the Sim card. That is the only way to access the SIM card on the iPhone... The actual phone can not be opened..
    May 05, 2010 | Apple iPhone 3G
    How do we put the sim card in
    on the Apple iPhone 3G Black Smartphone u will receive a pin the the box insert the pin on the top of the phone where u will have a small hole and will will get a slider to insert he sim try this and tell me incase any issues
    May 04, 2010 | Apple iPhone 3G Black Smartphone
    Apple iPhone Smartphone Logo
    75 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
