Question about Thetford Norcold DE0051 Refrigerator
Thetford Norcold DE0051 refrigeraror. It works on DC but not on AC
5 Suggested Answers
  • 68 Answers
SOURCE: Norcold DE704D won't switch to AC
http://www.thetford.com/LinkClick.aspx?fileticket=slRtJeja7H4%3d&tabid=497&mid=1316
This link will help with testing and resolve your problem. Can not resolve without these tests.
Thanks for using Fixya
Jerry
Posted on Mar 30, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Describe your Thetford Norcold® Model DE0061
Is there a switch so you can switch the unit to operate on ac? There might be, and it is switched to operate on dc right now.
Posted on Jun 28, 2009
  • 905 Answers
SOURCE: My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Posted on Aug 29, 2009
mgprice
  • 744 Answers
SOURCE: freezer cold refrigerator not norcold ac/dc/lp and no alerts
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Sep 03, 2009
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
Will work on ac but not dc. I checked that it has 12 vdc on the wire leaving the boat fuse panel.
Wiggle element out of sleeve and lift up while wiggling. Once element is out, attach to 12vdc from battery or other source and see if it heats up to touch, if not, replace it. Careful, may get real hot to touch.
May 19, 2010 | Thetford Norcold DE0051 Refrigerator
When on gas smells of exhaust fumes in van and
sounds like the burners need a good scrub to clear carbon off jets.
May 07, 2010 | Thetford Norcold DE0051 Refrigerator
How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Sep 21, 2009 | Thetford Norcold DE0051 Refrigerator
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Digital readout pad keeps cycleing
I still think it is searching for a power source. I have a parts breakdown and a troubleshooting guide I can copy and e-mail to you.
Send me an e-mail and I will e-mail the info back to you.
Jerry
rvtech@myway.com
Jan 15, 2009 | Thetford Norcold DE0051 Refrigerator
Thetford Norcold DE0051 Refrigerator Logo
65 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
