Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I need to find a manual for my SIERRA SPA 500 series.
Coleman 500 series yr. 2002, leaks near filter basket near the top.
try a new seal if doesn't work need new pump or pump housing
Apr 25, 2016 | Pool & Spa
Hayward heater h150 ignites and shuts off
check pilot generator if 500 millivolts to gas valve turn on switch if lowers should light if not check wires could be loose make sure flame sensor is above burner if not it wont sense flame
Jul 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
Unlock hot tub control panel
Panel needs to be in the display of "Time" 1st. If not, push the "Prog" button to get there. Once the Time is displayed, push & "Hold" the "UP" button for at least 5 seconds. The Lock icon/symbol will be displayed - panel is locked. Release and hold the UP button again for at least 5 seconds, the panel will then be unlocked.
Nov 29, 2013 | Pool & Spa
Find AC system low pressure port 1995 BMW 500 series
on the back of the compressor at the lower part of the engine.
Jun 02, 2012 | 2006 GMC Sierra 1500 2WD
I need an owners manual
Here is a copy of the manual for these pool filters. The first link is for the Pro Series S models. The second if for the pro series T models.
http://www.backyardcitypools.com/images/hayward/side-mount-filter-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jun 23, 2011 | Hayward SAND FILTER, PRO SERIES
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
How do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Oct 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I need an owners manual for a Coleman Spa Horizon series 447
Chuck, did you find the manual? If not I have one with my spa maybe I could copy it for you.
Ron
Sep 04, 2009 | Coleman Sport & Outdoor - Others
Pool Heater igniter wont light
Hi check out the power phile should be between 300 to 500 mille volts
Jul 11, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
115 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
