Question about Rheem Water Heaters
Ruud PVRP40-P #0704106052 won't fire up. Getting solid red LED error. what do I replace?
Just installed a Rheem RTG-95DVLN. Tried turning it on but all im getting is the # 82 flashing & beeping incessantly! Anybody know why or have any suggestions? Im completely stumped...
According to Rheem trouble shooting, at the end of page 61, error code 82:
Error Code 82
Explanation: Gas Type Control Data Failure; Printed Circuit Board data failure. The PCB has not
been programmed, lost its programming or has failed.
5. If the unit does not operate on initial installation or after replacement of the PCB, then the
circuit board requires programming with the fuel type and altitude chip.
http://hometips.me/Tls/SVC810-Rheem-Ruud-Tankless-Service-manual-2008.pdf
Feb 17, 2016 | Rheem Water Heaters
Why does my everhot heat pump have a solid red led?
There is such a thing as the light is simply telling you the heater is on and working. Is it? If not, the light is saying so. Different machines use lights in different ways. Be blessed.
Jun 23, 2014 | Water Heaters
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
Richmond water heater, goes into lock out
flame sensor error remove and clean with steel wool or replace but becareful because most of them have the ignitor and flame sensor on one bracket and the ignitor is fragile and most important don't touch it the oils from your skin will cause it to burn out
Mar 06, 2010 | Water Heaters
I have a ruud oil forced air furnace, but the model # says it is a Rheem ROBC-130. My problem is that the blower motor runs all the time, the furnace will fire and run for about a minute then shut off it...
this is more than a fan control relay . it is a black relay that will appear to have several wires connected to it but those wires connect to the base ,it unplugs , if it is set up for ac it might have 2 relays one toward the front one toward the rear replace the front one first ,,, if on good replace one @ rear should fix if not let me know
Dec 27, 2008 | Water Heaters
Water Heaters Logo
292 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
