I have Soyo monitor. The model No. is MT-PC-DYLM22R6. The screen is flicking and makes beep noise. Please help.
joey64
  • 209 Answers
SOURCE: PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Posted on Dec 01, 2007
Slinteriors
  • 8617 Answers
SOURCE: My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Posted on Jul 22, 2008
ginko
  • 19396 Answers
SOURCE: Lacie Desktop Hard Disk beeps when connected
No much help I can give, when an hard drive beeps it has motor error or head error, the disk hardwar is faulty, and you are not able to recover anything from the disk.
A safe data recovery can only be performed by specialized companies on a facility called clean room, where dust is completely removed from the room using a vacuum.
The data recovery using this kind of equipment does not cost less than $800.
Posted on Nov 23, 2008
SOURCE: Maxtor 3200 beeps but doesn't work
I have the same problem with an Iomega. After searching for a while i finally found this case report:
http://www.iomegasupportforums.com/phpbb2/viewtopic.php?t=15560&view=next&sid=8fcaf3c05f1bae35c079433c553ee28b
It seems that there is an "Onboard controller failure. It's not putting the drives in JBOD and only displaying one physical drive to your computer. You need to contact technical support about a replacement."
So it seems to be software but it still is a pain in the **** to repair/replace. But maxtor/iomega can charge whatever for a repair because your data is priceless right? sucks
Posted on Mar 23, 2009
  • 1684 Answers
SOURCE: dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Jan 18, 2012
Soyo sreen is black cannot sinc with my pc
this can be your computer issue not monitor try connect to other monitor and make sure your computer is working fine ,you can check all the lights on the computer are on and getting no beeps sounds usually you will hear a single beep when PC is booting well
Jul 28, 2016 | Soyo Computers & Internet
This monitor gives me a complete blank white screen when plugged in even after checking with multiple computers what part would need fixing or replacing for it to function properly?
check first any broken ribbon wire going to lcd panel or broken screen display. if those are good, the cause of white screen would be bad lcd controller board.
Dec 28, 2012 | Computers & Internet
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
I have a Soyo Citrine series Mod# MT-NI-DYLM2284 22" monitor, I heard a pop and now all I get is a dull-ish light blue screen. Nothing else. Attached another monitor to my PC. works fine. Is the...
It is fixable, however the cost to repair it will most likely exceed the cost of replacing it so you may want to take that into consideration.
Jan 08, 2011 | Computers & Internet
SOYO 19 TFT LCD Will not come on. Says "no input signal" Re-bot does not work. Everything is plugged in.
if the monitor has more than 1 source then make sure it is in the correct one. make sure the cable is fully inserted in the monitor and Pc. try another monitor to rule out a graphics card fault on the PC
Aug 02, 2010 | Soyo MT-NI-DYLM2058 Monitor
Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
