Question about Sony VAIO VGC-JS270J/Q PC Desktop
Mmy sony vaio VGC-JS270J desktop's fan is not working and in turn making my computer to overheat and shut down periodically
  • martin-r
    martin-r Apr 05, 2011
    Which fan? CPU, Power Supply, Graphics card or case fan (if you don't know, just say where it is in the tower).
  • barry_dillon Apr 05, 2011
    Thnx,it is the CPU fan. Apparently it is the only one inside. This is an all in one desktop with everything in the monitor as far as the components go. It doesn't look like there is a way to open it up and replace the fan but I'm sure there has to be though.
    Novelist:
  • 151 Answers
Ok, to open the pc, using a small screwdriver, remove the 14 square plastic/rubber bungs from the back of the case. this will expose the screws holding it together. Lay the pc screen - down on a soft, flat surface like a towel on a table. Undo all the screws and lift the back panel away this should give you access to the inner workings. Make sure you earth the pc by plugging - in the power cable but not switching it on. you should be able to get at the fan without too much trouble. if it is a moulded fan designed to fit only that pc, get the model number, if it is just a standard square framed fan, just measure it. You should be able to get a replacement fan from ebay for not a lot of money.
Give the case a good clean before re-assembling it (compressed air works best).
Good luck.
Posted on Apr 06, 2011
Random Restarting Issue with Sony Vaio VGC-RB30
send it in to check the fan inside if not cooled it could shut down and start back up when cooled
Nov 29, 2013 | Sony VAIO RB30C (VGCRB30) PC Desktop
Sony VAIO VGC-RA810G Desktop overheats and freezes.
Following are the reasons for overheating, just take care of these things::
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
Sony Vaio desktop VGC-RB34G has recently been shutting down abruptly without any warning or dialog boxes. The screen just goes black and the On/Off button does not respond. I have to unplug the unit to...
may be it will be your cpu over heating problem sou must clean ur heat sink and put heat sink compound on the top side of ur cpu, after you can install it heat sink back.if u stil have the same issue...just remove two screws from ur motherbord center screws. try it..
Oct 06, 2011 | Sony VAIO VGC-RB34G PC Desktop
Need to replace CPU fan
Write down the computer serial number and any other numbers that is on the computer and go to a computer store or order the CPU fan online. Make sure you have the right computer fan that fits your computer because if not the fan will not act properly as it should.
May 09, 2011 | Sony VAIO VGC-V617G PC Desktop
I replaced on My Sony VGC-LS25E the HDD from 250Gb to 500Gb reinstalled original Factory System with recovery works ok all day i shut it down like for 30 Mins and turn back on no video only 2 beeps put...
beep codes depend on the brand of the computer you have or on the bios they are using. for sony desktop computers, if you here 2 beeps, it means that there is a parity error. try to reseat the RAM/memory of the computer.
Jan 25, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
Is there a rest button on the Sony VAIO VGC-RB50 PC Desktop?
Do you mean Reset button?
Computers these days do not have Reset buttons. What you can do is hold the power button on for about 5 seconds and the computer will shut down. Press it again and the computer will boot up again.
If this is not what you mean, please explain futher.
Thanks for using Fixya.
Jan 09, 2010 | Sony VAIO VGC-RB50 PC Desktop
Shootind down automaticly
check the processor fan, maybe it shut....cause it's gettin hot and burn,
or maybe electric problem
May 29, 2009 | Sony VAIO VGC-RA820G (027242657700) PC...
Sony VAIO VGC-JS270J/Q  PC Desktop Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
