Question about Trust Computers & Internet
Mouse goes to sleep after about 2 mins if not used. Will activate again if I right click it. I have 3 computers the other 2 also with Trust Mice do not do this, I have tried the sleeping mouse on the other 2 computers and it still Freezes after 2mins and Ok after Right click. Thanks Arthur Fletcher
SOURCE: Mouse freezes
I had the same problem. The following solution from 3M support fixed it. We Normally see this problem on laptop computers running Windows XP. There is a power management setting in the Device Manager, which controls the USB Root Hub. Often this setting is selected to "allow the computer to turn off this device to save power". When control of the mouse is needed again, the computer is unable to turn the device back on. To remove this power management feature follow the instructions below. 1. Right click on the "My Computer" Icon on your Windows Desktop 2. Select "Properties" from the Menu 3. Click on the "Hardware" tab in the system properties window 4. Click on the "Device Manager" button 5. Click on the (+) plus sign next to "Universal Serial Bus Controller" in the Device Manager 6. Locate the "USB Root Hub" (Note: there may be more than one, and you will need to change all of them), double-click on the "USB Root Hub" to access the properties windows for that device. 7. Click on the "Power Management" tab 8. Remove the checkmark from the box containing the following option "Allow the computer to turn off this device to save power" 9. Click "ok" 10. Close the Device Manager and all other open Windows Test the Mouse to be sure that the new settings are working. You should now be able to leave the mouse unused without it being turned off by the operation system.
Posted on Feb 06, 2007
scott201201
  • 170 Answers
SOURCE: Does the mouse & keyboard turn off or sleep?
check your windows settings. They are in your power settings. You can adjust your computer to whatever you want.
right click on destop and goto properties, then click on screen savers tab.. see the power settting button now?? You should be able to tell it what to do for everything to do with Power.
Posted on Apr 09, 2008
serra_baby
  • 144 Answers
SOURCE: Mouse Right click doesn't work
hello!
o Install fresh batteries. Try brand new-high quality batteries you absolutely know are fresh and working.
o Install the latest software. Totally remove all software and reinstall from scratch.
o Try a different port and Resynchronize your device to the receiver. Try plugging the mouse into a different USB port try powering down the computer and using the PS2 port for the mouse instead. Mice in my experience overall work better using PS2 ports on PCs that have them.
o Clean the mouse lens. This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty.
Posted on May 08, 2008
  • 51 Answers
SOURCE: Mouse Problem
Possible solutions for this (and similar problems) include:
--Replace the batteries in your wireless mouse. If the connection strength is weak, wireless accessories have a tendancy to act up.
--Re-Install / update the mouse drivers. I'm unsure if Trust has drivers available for download from their website but it would be worth checking out if the first solution does not help fix the problem.
Posted on Jul 01, 2008
  • 63 Answers
SOURCE: Logitech V320 cordless mouse sleeps a while
get on to their tech support, they are generally exellent and should offer a replacement if they cannot help on the phone
Posted on Jul 07, 2008
Wireless Optical Mouse Mi-4150K doesn't connect to pc
windows 7/vista :
-step 1 :Press the windows button (start button).
-step 2 : In the search bar type device manager.
-step 3 : Open the device manager.
windows xp/2000 :
-option 1 for opening the device manager :
-step 1 : Press the windows button (start button).
-step 2 : Open the control panel.
-step 3 : Open the "System properties".
-step 4 : Click on the hardware tab.
-step 5 : Click device manager.
-Option 2 for opening the device manager :
-step 1 : Press the windows button (start button). -step 2 : Select "Run"
-step 3 : Type the following into the text box "devmgmt.msc"
-using the device manager :
-step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
-step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
This should almost force the computer to recognize the hardware plugged into the USB port.
Hope this helped!
Nov 06, 2013 | Trust Wireless Optical Mouse Mi-4150K
Monitor goes to sleep and won't wake up by moving the mouse 2009
there could be various things wrong with the computer which can only be solved by looking at the computer
i will give you a way to stop it from sleeping
1. right click on your desktop
2. click on properties, this brings a dialog box
3. select the screen saver tab in the dialog box
4. click on "power" button, this will bring another dialog box
5. select the "always on scheme" from the drop down menu or select "never" in all of the settings
6. click on ok
there you go now the monitor will never sleep again
Sep 30, 2009 | Computers & Internet
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
PC will not stay in sleep mode.
it's not a hardware-problem - it's a windows feature smile_wink.gif - (and it really is one !) - please try this:
To prevent a USB mouse from waking your PC
1. Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.
2. In the list of device categories, expand Mice and other pointing devices.
3. Right-click the entry for the USB mouse, and then click Properties.
4. On the Power Management tab, clear the Allow this device to wake the computer check box.
5. Click OK.
Don't forget to do this with your mouse + keyboard !
Mar 12, 2009 | Microsoft Windows Vista Home Basic for PC
Computer restarts
5. Click OK.
Don't forget to do this with your mouse + keyboard nd printer
Jan 28, 2009 | Samsung ML 1610 Laser Printer
Not on after pc comes out of sleep mode
5. Click OK.
Nov 09, 2008 | Logitech 967437-0403 Keyboard
Microsoft wireless laser mouse 5000
If you are using Vista Operating System this is a common problem.
!. Go to MY COMPUTER and RIGHT CLICK on it. 2. Then CLICK on PROPERTIES.
3. Next CLICK on DEVICE MANAGER.
4.Next CLICK on CONTINUE.
5. CLICK on the HID HUMAN INTERFACE DEVICE +.
6.Right CLICK on the HID NON-USER INPUT DATA FILTER.
7. Click on UPDATE DRIVER SOFTWARE.
8. When the screen comes up CLICK on SEARCH AUTOMATICALLY for UPDATED DRIVER SOFTWARE.
When finished the screen saver should work properly. Bud
Sep 26, 2008 | Microsoft Wireless Laser Mouse 5000
Monitor will not restart after sleep mode
5. Click OK.
Sep 12, 2008 | HP Pavilion a1710n (RK573AA#ABA) PC...
Apr 06, 2008 | Logitech Cordless Desktop EX110
USB optical wheel mouse not detected by XP
Hi, You can try to: Right click on "My Computer", click on Properties, click on the Hardware tab, click on the Device Manager Button, expand your Mice and other pointing devices. verify that you 2 entries. One is the Sony builtin (Alps in my Vaio) and a HID-compliant mouse. The latter is your external optical wheel mouse. Make sure it does not have any red or yellow mark. Double click on the HID and verify that the next window says "This device is working properly." If not follow on screen instructions to enable or activate. Hope this be of some help. Good luck and pls post again how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Logitech Wheel Mouse Optical
Computers & Internet Logo
35 people viewed this question
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
