Tv continues to turn off and the timer, lamp and standby/temp lamp flash on the power button
  • Anonymous Feb 15, 2009
    I have had the same problem. According to the manual, the combination of lights meant the lamp cover was removed (I had done this about a month before this problem statred to occur!).
    Someone on a site stated they had the same issues and with thiers the screws had worked themselves loose. There is a microswitch behind the cover apparently that wasn't having enough pressure applied to it making the TV think the cover was off. It says that he just tightened up the screws and it's been fine since.
    Must a flaw in the manufacturing for this to be happening to others as well.
    I'm going to try it to hopefully save on getting a repair man out - hope this helps!
  • Anonymous Mar 14, 2014
    standby-temp/lamp lights blink and the tv tries to turn on over and over
I had the same prob.{standby/lamp} and I did took the advice and just tightened the screws. I replaced the lamp 5 months ago. It must have worked loose.
Posted on May 12, 2009
I have the same problem did you fix it?
Posted on Nov 08, 2008
The power button flashes lamp +timer +standby temp
Hi This means you have to replace the lamp assembly. New Bulb.
If you are not trained to do this. Please seek help from your local TV repair man. Good luck.
Nov 28, 2014 | Televison & Video
Samsung DLP Flashing Lights
Make sure lamp is in correctly and as far as the color wheel: The ribbon cable from it to the DMD box only has connections on one side where it plugs in---it is possible to put it in backwards and set will detect wheel is not working..............
Jun 14, 2012 | Televison & Video
Samsung Flashing Lights
a new lamp is possible or even the ribbon cable from the wheel to the engine may be in backwards.
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Apr 08, 2010 | Samsung HLR6178W 61" HDTV
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Televison & Video Logo
458 people viewed this question
Top Televison & Video Experts
