Question about Dimplex DGWH4031 Heater
My dimplex fireplace is too noisy. It's been that way from day one. We should have sent it back, I guess. Everything else is great about it but it sounds like a 747 jet!
    Brigadier General:
  • 4,736 Answers
I have been dealing with electric fireplace/heaters for several years, now. And for the life of me, I can not think of a thing that would cause a noise like a 747 jet plane. Could you be a little more specific as to which function of the fireplace cause this noise?
Look forward to hearing from you.
Posted on Apr 05, 2011
  • cvcman May 07, 2011
    I have a Dimplex Hartford and there is a low hum from the flicker bar motor, They are sending me a new motor but I assume I will still hear it. If I remove the 2 screws holding the motor to the metal bracket and hold it in my hand it is wisper quiet. But as soon as it comes into contact with the metal bracket you get the noise vibration. I took the bracket off and put a pc of rubber tape between the bottom of the bracket and the unit bottom. It helped but its still there. My wife cant hear it and im tuned into it now. Every time you up the flame speed the noise goes up an octive higher. The second to the highest speed makes a nasty vibration sound.
    Wish there was a way that I could make it as quiet as it is when im holding it in my hand. I tend to have a little OCD so that doesnt help either...Other than thaht its a nice unit but not sure its worth the 1200.00 we paid for it
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
My customer just bought a CS 1205 from our True Value Store. The blower on the new CS 1205 does not work. It has been used three or four time. The flame comes on however. What do you suggest?
Before call Dimplex Technical Service (888-346-7539) have your customer turn the Master ON/OFF Switch to OFF. Unplug the fireplace for 12 - 15 minutes. Once plugged back in, have them turn the Master ON/OFF Switch to On and then turn ON each function of the fireplace one at a time. If everything is performing as it should, the unit reset itself. However, if this becomes a recurring problem, they should contact Dimplex Technical Service.
Hope this helps you solve the problem for them.
Apr 05, 2011 | Dimplex CS1205 Electric Compact Heater
Dimplex 3015 purefire remote will not torn fireplace on or off. Tried to reset remote, but no results. I have 2 fireplaces of the same type, and an old and new style remote. Tried with both remotes, but...
Apparently, the receiver on one fireplace is faulty. If this a plug-in wall type receiver, unplug it from the wall, wait 5 minutes and plug it back in. That 5 minutes may have given it time to reset itself. If you see any scorch, burn marks or melted plastic on the receiver box, it will have to be replaced. Contact Dimplex USA, Technical Service Dept at 888-346-7539.
Hope this "remotely" helps to solve your problem.
Mar 10, 2011 | Heating & Cooling
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Help
Dimplex has a number for you to call: 1-800-668-6663 ext# 358 TELL THEM YOUR PROBLEM AND THEY WILL PUT YOU IN THE RIGHT DEPARTMENT. I had problems with the main switch and they sent me a new one.
Nov 05, 2008 | Dimplex Compact Electric Flame Stove...
Dimplex DGWH4031 Heater Logo
681 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
