Question about Sony SLV-740HF VHS VCR
Sony slv t2000 will not eject tape. Any help please.
5 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Posted on Apr 16, 2007
  • 883 Answers
SOURCE: Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Posted on Feb 05, 2008
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Posted on Mar 02, 2008
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
How can an NTSC 8mm tape be played on the Sony SLV-T2000?
There is no way to play 8mm tapes on your vhs vcr. You would need a 8mm to vhs adapter which is not available.
Nov 10, 2009 | Televison & Video
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony vcr model slv-m91hf
make sure the tape is not missing its tab which is on the left hand side of the tape at the back
Dec 09, 2007 | Sony SLV-M91HF VHS VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
VCR won't take tape
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Mar 11, 2007 | Sony SLV-ED85 VCR
Sony SLV-740HF VHS VCR Logo
425 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
