Question about Whirlpool Dryers
My dryer spins but doesn't heat. Can I assume it's the thermostat? If not what's the best procedure to find the problem. the circuit breakers look fine.
  • 59 Answers
It could be the tstat, or faulty heating element.
Posted on Apr 06, 2011
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Amana electric dryer LE8317W2 tripped circuit breaker. Orange wire fried at end by heat element and was off terminal end. Also the purple wire was fried at thermostat end. I cleaned up connections and...
These units are totally repairable and will run for ever. Need to assume that other damage has occurred as a result of the failed shorted terminal connections.
Possible that the circuit breaker is defective caused by the dryer failure.
Assume that one of the components has shorted to the grounded frame of the dryer.
The 11 ohms of the heater is about right.
Confirm that heater element is not shorted to the dryer frame (heater housing)! This condition would have caused the initial wire terminals to fail and now trip the circuit breaker!
Use an ohm meter and check resistance between hot leads on back of dryer. Check resistance between each hot and neutral.
There is a switch located on the motor that connects power to the heater. When the motor is running the centrifugal switch closes. This saftey circuit confirms that the blower is running before heat is turned on. Check that the switch is not damaged from prior terminal short circuit failure, Repair kit is p/n WPL-501218
Timer is the next check. Same thing confirm that no damage to the switch circuits has occured. Last check thermal fuses and thermostars for short to netural.
Hope this helps?
Jun 25, 2017 | Amana ALE643RB Electric Dryer
Electric dryer trips circuit breaker after about 5 min when running at high heat not sure of model number
Most likely culprits are the thermostat (or a short in the wiring related to the thermostat) . I am assuming it is a normal current breaker and not an earth leakage breaker. It seems likely to be the thermostat as that probably switches after a few minutes (whereas the element which is also a common failure is on from the start of the cycle, so if there was short in the element that would take the breaker out immediately).
Does it do the same whatever heat setting you select?
If you switch it back on before letting it cool to much does it trip sooner?
If the time it takes to trip changes when you change the heat setting that would point to the thermostat/wiring too.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 15, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Just installed new ciruit breakers and the dryer runs but still will not heat up. What should I check next
I have to assume at this point your changed the Circuit breaker in hopes of correcting you no heating problem. There are serveral things that can cause your problem. 1 an open heating element. 2 a defective thermostat. 3. a bad motor switch and 4 one of the 2 circuit breakers is partially tripped. These are the most comon problems but a loose connection on one of the terminals inside of your dryer can also result in the wire being damaged due to excess heat build up. If you need exact locations for these items post back and I will help. .
Jan 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not heat but will run.
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wil not spin
May 08, 2009 | Dryers
Dryer not putting out warm to hot air. What is the issue?
May 07, 2009 | Dryers
Dryer takes too long to dry clothers and yes I cleaned all the vents and there is no clog or stoppage in vents
May 06, 2009 | Estate TEDS740JQ Electric Dryer
My Dryer Will Not Warm Up Or Heat Up At All!!!
May 05, 2009 | Dryers
Where is circuit breaker in a LG DLE9577WM dryer
it could be the thermostat it could be a burned heat element if electric verify gas or electric
Mar 05, 2009 | LG DLG5932W Gas Dryer
Dryers Logo
16 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
