Question about Olympus SP800UZ Digital Camera
I have a new SP-800UZ that will not focus sharply on distant objects using the 30 X zoom. Do you know how i can get rid of the problem or get rid of the camera. I have tried all settings but mostly on P Auto. This morning I took some wide angle shots and after viewing the picture using the zoom close up to review the picture it is not very sharp. Disgusted with Olympus. Bill Martin April 5th 11: 59 AM
    Novelist:
  • 151 Answers
Look within the settings within the camera's setup menu (I am not too clued-up with this model but I'll try) Look for things like sharpness, photo effects, ISO modes and resolution. make sure the sharpness is set toward the sharper end of the scale, that there no added effects enabled and that the ISO mode (if not in auto) is set between 100 and 600.
Also, if you are using digital zoom you will reduce picture quality.
Finally, using maximum zoom requires a very steady hand (or a tripod) as the slightest shake or twitch will be amplified many times at the target - end of the shot.
Good luck Bill, hope this helped a bit.
Posted on Apr 05, 2011
  • Willem.
    Willem. May 01, 2011
    Sharpness, read Focus, can be not optimal when using the autofocus.
    Try Menu setting:
    Compression: Fine (to have more detail)
    AF Mode: Spot (instead of default Face/iESP)
My old camera was an Olympus Camedia c-765 digital. My new one is an Olypmus SP-800UZ 14 megapixel. The more I use the SP-8OOuz the more disappointed with the pictures I take. None of them seem sharply in...
No, you are not wrong. When there are more pixels, the picture must be more clearly and you can zoom it more. Because you have experience with another Olympus camera, I'm inclined to believe that
something is wrong with your new camera. Try to put it on AUTO mode and see the difference.If everything will be ok, it means that you are wrong when you set the manual parameters.
Mar 24, 2011 | Olympus SP800UZ Digital Camera
Can the camera sp-800UZ take rapid shots pics with flash going off every pic taken
In short, no. As with all flashes, the capacitor takes a while to recharge (via power from the low voltage battery which is amplified to many thousands of volts in the capacitor) between each shot. How long exactly depends upon how far it's discharged each time, so for close-up objects which fill the frame and need little flash, the discharge will be relatively low and you may get a few shots off in a row, and for distant objects using a more powerful flash discharge it may totally discharge with each shot.
The bigger and more powerful the flash unit, the better it will perform in that respect which is why professional external flashguns are big, bulky and cost hundreds or even thousands of dollars. A built-in flash such as on your camera is a compromise solution and is not intended for heavy use. More advanced cameras may have their own built in pop up flashes to take close up snapshots, but for anything else have connectors to enable the use of more powerful external units.
Mar 04, 2011 | Olympus SP800UZ Digital Camera
How to align pointer? which lens tu use? no zoom?
During the daytime point the scope at a distant object like the top of a telephone pole. Without moving the scope adjust the small finder scope crosshairs so they point to the same spot.
Put the eyepiece with the largest number written on it into the diagonal. This is your lowest magnification. Practice focusing on a distant object using this low power eyepiece.
Dec 29, 2010 | Konustart 700 (120 x 60mm) Telescope
Can I zoom when recording on the olympus sp 800
Zooming when recording video on the Olympus SP-800uz is only possible when the sound is set to off. Set the zoom to the setting you want before recording, after that start recording.
Dec 13, 2010 | Olympus Bag / Case For Sp-600 Sp-800...
What is macro used for
It's used for extreme close up shots. The setting allows the autofocus to focus closer than it normally can, but may prevent it from focussing on distant objects.
Sep 20, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
How to use
Put the eyepiece with the LARGEST number written on it into the telescope. Go outside during the day time and practice focusing on a distant object.
This is your LOWEST magnification. Then try other higher power eyepieces. While you are out there focused on a distant object. Line up the small finder scope on that object without moving the telescope. Use the small thumb screws on the finder scope to put the "X" crosshairs on the same object as you see in the eyepiece.
Dec 18, 2009 | Meade Optics
I see a big X where I should see planets and stars. How do I get rid of it ASAP??
You are NOT focusing the telescope properly. Put the eyepiece with the largest number written on it into the telescope and go outside during the daytime and practice focusing on a distant object.
Sep 27, 2009 | Galileo Optics
PowershotSD750 Focus More
Press the left mode-wheel (the side with the flower and mountain icon) until you see the flower (macro) icon in your screen. You're now set to focus on close-in objects, such as type. When you want to switch back, press the left side of the mode wheel once more until you see the mountain icon. You're now set to focus on more distant objects.
May 17, 2009 | Canon PowerShot A75 Digital Camera
Celestron astromaster 114 EQ (problems zooming in)
Most telescopes do not have a zoom-- they have different numbered eyepieces that give different magnification-- you can buy a zoom eyepiece however.
From what you describe -- put the eyepiece with the LARGEST number written on it into the telescope-- this is the LOWEST magnification. Now focus on the moon and or a distant land object during the day-- once it's in focus -- nice and sharp-- replace the eyepiece with the next LOWER number-- for more magnification. AND-- refocus the telescope for that eyepiece.
Feb 11, 2009 | Celestron AstroMaster 114 AZ (50 x 114mm)...
I Cant see ANYTHING.
Put the lowest magnification eyepiece in the telescope-- it's the one that has the LARGEST number written on it.
During the daytime, go outside and point the telescope toward a distant object at least 100 yards away and practice focusing the telescope--- turn the focus know very slowly. Do this until you learn how to get a clear view of the distant object.
Once you have it focused wait until dark --- don't turn the focus knob. Your first sky object should be the moon or Venus -- which is the BRIGHT "star" in the west after dark....
Dec 29, 2008 | Vivitar (1607225) Telescope
Olympus SP800UZ Digital Camera Logo
97 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
