The compressor only reaches 55 psi and never stops
  • 3 Answers
If you are not hearing any air leaking out, then you may either have a gasket inside the compressor blown or you may have a cracked or broken ring on the piston located inside the compressor.
Posted on Apr 05, 2011
I have a Central Pneumatic 38898 pancake compressor that will not shut off when the pressure reaches pre-set PSI. I have replaced the pressure switch but to no avail...HELP!!
There must be a blockage on the fitting where the pressure switch goes in that stops the air pressure from reaching the regulator. Try taking the switch off and turn the compressor on and see if air comes out the hole
May 23, 2015 | Air Tools & Compressors
1989 s 10 blazer won't take freon has 55 psi on low side while filling with comp. On only 20 psi high side where should I look for prob.
Sounds like the fittings are reversed.
With the compressor running, the low side should drop below zero then climb to 60 or 80 psi as you add freon.
You would need to jumper the low pressure switch to engage the compressor clutch to add freon. The compressor must be running.
Mar 22, 2015 | Cars & Trucks
Compressor slows down bfore stopping then stops, but motor is still trying to run psi has not yet reached
Depending on size of compressor there is at least 1 check valve on tank &/or on head. The check valve is either gummed up or bad & will need to be cleaned or replaced.
Jan 17, 2011 | Air Tools & Compressors
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Motor "bogs down" at roughly 120 psi...almost stops
You suspect this unit as being a two stage because of the unusually high cut off pressure. It is a single stage and the motor really has a difficult task and is being pushed to the limits. to reach this pressure. We usually reset the pressure to lower setting ~~ say around 140. Your pump probably has a leaking intank check valve (brass fitting at tank) or leaking valve plate in pump. Simple tests : with pressure in tank unplug compressor from outlet and listens for air leak around pressure switch. As you unplug the running compressor from outlet you should hear air leaking from pressure switch for just a moment as air is let out of airline from pump to tank. If air leaks out till zero pressure then change the valve. If tank holds pressure then valve probably ok. Next test, with no air in tank and air filter removed, plug in compressor and feel intake port for strong suction. If the valve plate is bad, suction will decrease as pressure neers the 120 mark till the point of feeling that air is actually blowing out of intake. With good valve plate there will be strong suction untill unit reaches set pressure. If valve plate is bad also change the cylinder and piston ring. Good luck with your repair.
Jul 28, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
Porter-cable compressor stops and restarts at about 60psi
You prolly have a leaky gasket in the main valve. Air is leaking and causeing it not to go about 60psi, you probably have it set to reach a high PSI but since the leak is not allowing it reach above 60 it keeps cycling trying to get above it
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Air compressor switch
That means that when the switch is turned on , and the complessor is pluged into a power outlet, the electric motor will start when the air pressure in the tank drops below 80 psi.and the motor will stop when the pressure reaches 100 psi.
please rate this,
Rob...
Aug 30, 2008 | Air Tools & Compressors
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
