Question about Toro Lawnmower 20099 Mower Mowers Lawn
When I pull cord to start, the cord moves about 4 inches and then stops dead.
  • 577 Answers
You need to pull your spark plug and check that cylinder is not hydrolocked with fuel or oil first, then with plug out see if it will pull the motor over or pull out any farther than it did before. If everything is good there, I would check underneath the deck and see if you can spin the blade by hand,(make sure your spark plug is still out for safety) next I would pull the rewind top off motor and visually inspect the Flywheel and coil gap and look for something possibly binding or catching on the flywheel, I think that model has a flywheel brake, maybe that is not adj. correct.....good luck hope I gave you some ideas, If by chance the cylinder is full of gas..replace needle and seat in carb.
Posted on Apr 06, 2011
Was running stopped. Starting pull cord only moves a couple of inches then feels like engine gets locked.
indications are that the ring has seized or broken in the cylinder
check the oil/fuel ratio in use as it may be a bit on the lack of oil side
Nov 19, 2016 | Garden
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My fan was working very well and all of a sudden it stops like it has a shock and when i moves the chord it starts back to work but now it just stop completely and is not workin for like a month now
Hi miahpurplean...
You have a broken electrical cord, it is probably broken inside of the fan.
Not too big of a problem...take fan apart, cut about 6 inches of the cord off from where it was attached to the fan and reattach the new wires that you exposed when you trim the plastic from the cord (about 1/4 inch).
Your fan should work again after this.
Please take time to rate me
Aug 12, 2011 | Lasko 1850 Stand (Pedestal) Fan
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Any idea how to reset it or at leat open the lid?
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 26, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
May 23, 2009 | Garden
Poulan 16" cannot start...pull cord locked up
Remove the cover, should be 4 screws that holds it on once the 4 screws are loosened the rope could rewind on its own. If not check to make sure the spring is not broken.
Apr 06, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Toro Lawnmower 20099 Mower Mowers Lawn Logo
449 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
