Question about Acer Aspire 6920 Notebook PC
My Acer 6920G has problem; While computer is on using battery,no problem, but if cord AC is plugged in (AC adapter) computer shut down unexpectedly.Help me to solve it,Thanks. Hadi
    President:
  • 2,340 Answers
Looks like your power adapter for your laptop is short-circuited. Replaced it with a new adapter.
Hope it helps.
Posted on Apr 05, 2011
  • bastian433 Aug 27, 2011
    I have exactly the same problem, but on battery it also seems to shutdown in windows normal mode.
    It runs fine in safe mode.
    replaced all cooling paste, cleaned fan/heatsink, replaced harddisk, measured powersupply, nothing helps. probably faulty mainboard
  • yaoyang Aug 27, 2011
    Aspire 6920G, asumption, you are on OS Vista, update your Windows , Device drivers & Bios vesions to latest, link @"http://support.acer-euro.com/drivers/notebook/as_6920G.html"
    ***Caution updating the Bios is not for any novice Users
    @bastion, remove the battery and run the laptop from the direct power source, failing battery do cause it to shutdown.
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Power light turns green then shuts off in 1 second or less
Check that the computer is plugged in with power. (is the power bar actually on?, the power cord lpugged into the brick? plugged into the back of the computer? Is teh power port loose/broken?)
Mar 17, 2011 | Acer Aspire One PC Notebook
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
Dec 16, 2009 | Acer Aspire 6920 Notebook PC
My acer 4520 laptop shuts off while using it. why? cant seem to complete any task without powering it back on.
This may sound stupid, but it could be as simple as your battery being low. If the battery is charged and it is still shutting off on you, the battery may need to be replaced.
One way to verify this would be to remove the battery, and plug the computer into the AC Adapter and see if it runs properly.
If it works fine, then you know that there's a problem with the battery. If not, then it may be something more serious like a motherboard issue. If it gets to that point, I suggest you take it somewhere that it can be physically looked at.
Hope this helped :)
Nov 29, 2009 | Acer Aspire 4520-5582 Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Acer Aspire 6920 Notebook PC Logo
241 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
