Question about Crosley Washing Machines
MY CROSLEY FRONT LOADER WILL NOT DRAIN OR SPIN SHOWS A CODE OE
  • 4,323 Answers
Hi
OE error means that the water is unable to drain completely and the bottom front access panel has to be taken apart and then the drain pump-filter assembly should be cleaned. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 05, 2011
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Crosley CFW8000GR OE Problem
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
