Question about Honeywell Heating & Cooling
How to set humidistat for different seasons. - Honeywell Heating & Cooling
    Brigadier General:
  • 4,736 Answers
Vick, depending on the season and the humidity level in your home, is what determines the setting. For example, in the winter you want to maintain at least a 40% humidity level in your home. It will feel more comfortable, the heat will feel warmer and it will help keep static electricity at bay. In the Summer, you'll want to remove as much humidity as possible, as this will make the air feel cooler. If you have ceiling fans in you home, run them Clockwise at the highest speed you can tolerate. The more wind chill you generate, the cooler the air will feel and you won't have to set your AC at a lower temperature. Thereby, saving money. In the winter, run the ceiling fans Counterclockwise on the lowest speed. This will take the heat off the ceiling, wash the walls and bring it back down.
Clockwise and Counterclockwise are determined by looking up at the fan blades. Also, reversible ceiling fans have a switch on the side (where the pull chain is located). Generally, switch-up is Counterclockwise and switch down is Clockwise.
Hope this helps you to keep your home comfortable year round.
Posted on Apr 05, 2011
Solenoid valve
The humidistat could be defective.
Dec 04, 2013 | Aprilaire 700 Humidifier
Diagram wiring
You could replace the Thermostat with one that allows you to to set it lower, or get a different humidistat that goes from 0-90 , There is always ways around, Thus this great website.
If you need more details or where to purchase let me know.
Oct 10, 2013 | Danby DPAC12099 Air Conditioner
Wire Honeywell HE220 to N8MPN/L, *8MPN/L furnace control board
HI
I have similar isssue with HE220 but in my case the water run through all ththe time, even when unplugged from the power outlet.
Would that be solenoid issue?
the unit run fine for last season so the wiring is fine.
Any ideas would be greatly appreciated.
Jan 22, 2012 | Honeywell HE220A1019 Whole House...
Humidifier will not turn on (no fan, no water flow)
http://www.appliancefactoryparts.com/humidifiers/helpcenter/breakdowns/honeywell/honeywell-he360a1027.html
A breakdown diagram of parts etc above.
http://www.appliancefactoryparts.com/content/pdfs/110672-4.pdf
Shows you the HE360A.
To me it sounds like it is wired incorrectly, the solenoid should NOT get too hot at all. The PDF above shows wiring data.
Apr 03, 2010 | Honeywell HE360A1027 Whole House...
The 700 will not start for this season. I called
reason why I asked they sometimes have a problem sensing current and you may need to wind the wire twice instead of one pass. If you jump the wires at the humidistat and the unit turns on its either the stat or you may want to do a relative humidity check on the house to see where your at
Best regards,
Tinner
Dec 13, 2009 | Aprilaire 700 Humidifier
Loud clicking and banging, A700 doesn`t work
You have a faulty humidistat
Greg Sunsetmech
I have a Honeywell House humidifier HE 225A-1006.
In order of probability:
1) (incorrect wiring) Make sure that humidistat is in SERIES wired with the furnace.
2) (shorted wires) Check that two wires to humidistat are not touching...use your glasses if you need them!
3) (bad humidistat) disconnect the humidistat and put an ohmmeter accoss the two terminals when it is turned on you should read 0 ohms, and when off it should read infinate ohms, if not pass both these tests, you need new humidistat.
That is it, there are no other possibilites!
Oct 12, 2009 | Honeywell HE220A1019 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
Heating & Cooling Logo
81 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
