Question about Panasonic Audio Players & Recorders
The DVD/CD tray will not open on our Panasonic SA-PT860. Can you help?
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
SOURCE: Panasonic SA-HT700 Home Theatre - Tray won't open
i have the same issues. Just took a screw driver to the four sides and opened it up. Took 5 mintues. Pulled them out.
Posted on Jul 10, 2008
SOURCE: Open/close disc tray won't open
I have a Panasonic SC-HT810V home theater system and the dvd door will not close after inserting disc.
Posted on Jan 19, 2009
SOURCE: broken tray Panasonic SA-HT820V
The mechanism gears are probably out of timing. If you are mechanically inclined, you can fix it. You need to find the service manual and in it there are about 10 pages of step by step directions on how to take it apart and align all the gears. it take some effort but it is much cheaper than buying the whole tray mechanism and I doubt that any parts are broken.
Posted on Jul 30, 2009
SOURCE: DVD trays out - Panasonic SA-PM39D
the system i had, had exactly the same problem, happened years ago but only got around to it now.
The case is quite fiddly and there are also potentially dangerous voltages inside so i would only do this if you are trained, and even then you do so at your own risk.
I have fixed the problem but i am not 100% on what the actual problem was. firstly i opened the system up and seeing as the problem was the stuck trays i went straight for the dvd mech (part 1) however that may not be necessary and the problem may have just been the front switches not reading properly (part 2).
**make sure the unit is unplugged**
Part1
-take sides off
-loosen front panel from base of system
-i removed the white plastic top of the dvd unit allowing you access to the screws holding the metal panel on to the dvd unit, removed the metal unit.
-there are two ribbons connecting the dvd unit to the main unit, the smaller one controls the motor drives.
-i plugged in the unit to test the motors, to do this i ground each pin coresponding to a motor (they are labelled) located a the header at the end of the smaller ribbon. (This can be done from the other end of the cable located on the side of the unit, which is much more accessible but not labelled)
-forced dvd trays back to their starting position (makes lots of noises)
-on the side of is a sliding mech that selects which dvd tray i made sure that moved back and forth freely (quite stiff as you are working against the motor) you should hear the motor turning.
put everything back together.
-when switched on it would go through starting sequence but NOTHING else.
Part 2
-mech appeared to working but noticed front panel was not responding to button presses on the dvd area. the tape/dvd select and power button were OK though
-removed front cover and removed front panel circuit board, plugged back into system.
-without the front panel the buttons all worked and system all worked.
-replaced front bezel and system worked.
j uk
Posted on Aug 11, 2009
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Can I change Panasonic sa-pt860 DVD player to bluray player?any bluray player can fit into this home theatre?
Most BluRay players will work with home theaters. HDMI cables can be adapted to VGI inputs if necessary.
Dec 09, 2014 | Panasonic Televison & Video
Manual for SA-PT860
http://elektrotanya.com/panasonic_sa-pt860.pdf/download.html
Should get you to a site where you can download the Manual.
Good luck. Hope this helps!
Jun 26, 2012 | Panasonic Televison & Video
Cd tray won't open
get it serviced as it happens due to the old band or ring kinda thing in the tray which aids in opening of it.
Aug 28, 2009 | Panasonic SA-HE70K
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Multiregion unlocking code
Welcome to standalone DVD Player Region-free unlock guide. On our pages you will find a lot of verified working unlock codes collected from many different sources.
Whilst we made every effort to ensure that the information contained inside these pages is both accurate and up-to-date, we take NO responsibility and accept no liability for any damage caused from applying these procedures as laid down on these pages.
Use them at your own risk!
DVD Player model: Panasonic SC-HT80
Open CD drawer.
Press 9, 8, 1, 7 on the remote control.
Press ENTER till it shows region 9.
Press RETURN.
Apr 25, 2009 | Televison & Video
I HAVE A PANASONIC SA-CH72 STEREO SYSTEM. THE CD TRAY DOES NOT OPEN. IS THERE A WAY i CAN OPEN THE TRAY AND GET OUT THE CD THAT IS THERE, OR PREFERABLY FIX THE TRAY? BTW THE FRONT COVER TO THE TRAY...
Unplug the unit, then unscrew the metal cover over the top and sides of the unit. Then unscrew the black plastic cover that goes over the top section of the back. This will allow you to get out a CD that is stuck in the back.
Jun 15, 2008 | Panasonic Televison & Video
349 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
