Question about Canon imageCLASS MF6530 All-In-One Printer
I can't get my Canon imageclass MF6540 to scan via my network. It gives me an error code: 2,255,0. What's the deal?
The scan function only works via USB, print and FAX are available via network and USB.
Posted on Feb 23, 2012
2 Suggested Answers
SOURCE: I HAVE A CANON IMAGECLASS MF6540. DISPLAY STATES
Your printer has a bad IP Board. If it is still under warranty you will have to take it in to an authorized Canon dealer and have them replace the board. Other people have given the solution that it just needs flashed because the boot information is corrupt or missing. This is the case but there it no firmware to download to correct the problem. The board has to be replaced. The repair for this can range in price but the dealership around me wanted $660.
Posted on Nov 11, 2010
How do i get canon imageclass mf 6540 to scan
Such printers with scanners built into them are know as Multi Function Printers. It is possible you have downloaded a 'printer only' or generic printer driver software.
Here are the links to the 3 bits of software you require:
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100242106EN.htm
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200155901EN.htm
3 (only for 64 bit windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114601EN.htm
3 (only 32 bit Windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114501EN.htm
May 05, 2014 | Canon ImageClass MF6540 Copier
I have a cannon image class MF6540. When I try and print I get an error "out of paper". I have plently of paper. I am able to copy but not print.
I assume you are trying to print from your computer.
The driver for this unit will give you an out of paper message almost any time it won't print for any reason.
If the unit copies, but does not print from your computer, then it is a communication issue. Perhaps uninstall/reinstall the driver?
Mar 24, 2014 | Canon ImageClass MF6540 Copier
Service manual mf6540 canon
hello friend, you can find the canon mf6540 service manual in below link:
Canon imageClass mf6540 service manual:
http://goo.gl/kW6ZF5
thanks
Apr 22, 2012 | Canon ImageClass MF6540 Copier
Canon ImageClass MF6540- works fine for printing, but scanning complains connection problem on Dell Dimension E521. However my other Dell Dim 9200 computer runs fine for both printing and scanning. What...
Need some clarification about the error.
We need to know the exact error.
Generally all the scannars use TWAIN technology which bridges the scanner with WIA(windows imaging aquisition).
We need to know if WIA which is a part of the operating system is working. For diagonasting we can try using teh scanners and camera wizard from control panel or we can use mspaint even.
If WIA is working in that case the problem may be with the registry values of the scanner.
WE can try making a new user account with admin rights and then we can try installing the scanner. We can even try using Revo uninstaller for uninstallation of the scanner because it will remove all the entries from registry, then we can try scanning.
BEST OF LUCK.
Feb 11, 2010 | Canon ImageClass MF6540 Copier
My Canon MF6540 is only pulling paper about 3/4 of way through when I am trying to scan/copy. There is no paper jam, and I have cleaned the machine. What could be wrong?
Does machine eports some eror like paper jam or similar o e001, ...
Check the paper sensor flapper on fixing unit, or clean all rollers with alcohol or water
Jan 29, 2010 | Canon ImageClass MF6540 Copier
Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Aug 22, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Canon ImageClass MF6540 scans but has error light
use your computer go to command promt and do ping to copier machine ip add, see there is any reply .If there is reply ,your machine is connected to your p.c.then use the printer driver do a test print.
Aug 19, 2009 | Canon ImageClass MF6540 Copier
Canon imageCLASS  MF6530 All-In-One Printer Logo
1,084 people viewed this question
old marine
old marine
