Question about Magic Chef CYE4000AWW Electric Dryer
My dryer was running then stopped. It smelled like it overheated. I flipped the circuit breaker. That is fine. There was too much lint so I cleaned it out and was ready to order a thermal fuse, but then saw it might be something else. What do you think?
    Sergeant:
    Champion:
  • 202 Answers
Hi... I would get the Hi-limit Kit as well
Posted on Apr 05, 2011
My Whirlpool LTE5243DQ1 has stopped working, neither the washer or dryer will work or make any kind of noise, I have checked the power cord and the fuse box and both are working properly what else could...
Make sure the dryer isn't full of lint behind the panels; throughout the components of the lint extraction and back in the wiring components of the dryer. Mine stopped working and a thorough cleaning of the above solved the problem. My washer was working, however, before this process. I first checked circuit breakers (no help) and the thorough cleaning did the job. If there is overheating, there is some kind of safety shut off.
Aug 02, 2011 | Whirlpool LTE6234D Top Load Stacked...
Had "burning" smell during dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Feb 27, 2011 | GE Dryers
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Replaced element but still won't heat, tumbles, and circulates air fine. Wiring looks fine but won't heat.
You in all probability have a burned up high temperature cutout...a very small unit fastened someplace on the sheet metal in the back inside part of the dryer that senses when the dryer is overheated. You will need to find it and replace it...low cost item usually under $15. If you test with an ohmmeter with one of the 2 wires disconnected you can find where it has an open circuit on the bad part....replace it and the unit will do fine...then make sure that the lint is cleaned all inside the dryer and the vent pipe...for safety and to make sure you do not blow another safety device.
Aug 22, 2009 | Dryers
Whirlpool compact dryer won't start.
If lint screen is not cleaned, it can block air flow causing the unit to overheat and it should shut off on a safety. Usually a thermal activated device. I'm kinda thinking that's not whats going on though. When pushing the start button, this activates the "Start" circuit in the motor. Once the motor gets up to speed, usually in less than 1 second, it will continue to run. I would look in that direction. Either in the starting circuit or the motor itself.
Good Luck
Feb 27, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
NO HEAT DRYER
alot of dryers have temp overload fuse
Dec 20, 2008 | Whirlpool LGR7646E Dryer
Dryer is on and tumbling, but not heating up
Most driers have a overload cut-out switch to protect the element from overheating
these are usually on the right hand side of the ( Bump / hump panel at the back ) should be a plastic thpe button that re-sets the overload
- got to be worth a try
Dec 17, 2008 | Whirlpool LEB6300 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Magic Chef CYE4000AWW Electric Dryer Logo
90 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
