Question about Royal Office Equipment & Supplies
Tapping the space does not advance the carriage. Neither does typing.
  • mgraff3221 Apr 07, 2011
    Thanks. I will have to find a repair shopping in or near the western suburbs.
    Champion:
  • 204 Answers
Probably a broken, stretched or dirty belt. clean it with alcohol.
Squipps
Posted on Apr 07, 2011
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
Typewriter will not space
It sounds as if the spring in the drum under the carriage has broken. Major problem.
Mar 07, 2010 | Office Equipment & Supplies
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 31, 2009 | Office Equipment & Supplies
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
IBM Wheelwriter 5--Carriage advance problem
Try code (lang) key either the X or L depending on when it was made
DickyO
Dec 31, 2007 | Lexmark Wheelwriter 5 Series II Typewriter
IBm Wheelwriter 5--6 keys won't advance after typing
Press and hold the code key while pressing the lang key Either "X" of "L" key.
DickyO
Dec 31, 2007 | Office Equipment & Supplies
262 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
