Question about Microwave Ovens
I have a le creuset non stick frying pan. The suface is flakng off. Can I get it resurfaced? Many thanks Ian
5 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Posted on Jan 29, 2007
jyackle5
  • 8197 Answers
SOURCE: how can I fix a
The only way to fix your pan is to send it to the link below.
http://www.coatingsolutions.com/?gclid=CPD7kZ_Ns6UCFSdtgwodPwEAZg
Good Luck
Posted on Nov 22, 2010
  • 15 Answers
SOURCE: I have a black sticky
Go to epinions.com, type your product and find you are not alone. Besides, as there is no cure to baldness there is no such thing as a perennial non stick pan. All coatings invented eventually succumbs to the wear and tear produced by temperature changes, contact with food and related chemistry, detergents, scrapping, etc. Consider the possibility that some of that non stick material may be ingested unconsciously.
Posted on Dec 18, 2010
  • 2509 Answers
SOURCE: I have an old Le
It probably needs re enameling but the good news is that Le crueset guarantee for life. I can't point you at a link as i dont know where in the world you are but if in the UK see here
http://www.lecreuset.co.uk/Care--Use/Cast-Iron/
hope that helps
Posted on Jan 25, 2011
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
Can i refurbish my non stick pan. Some of my friends used a knife and made some nasty marks. can i get this fixed
At best you can recycle. Once the skin of the coating is compromised, there is little or nothing you can do to re-coat the surface with a coating such as the factory coating.
I use pans with compromised seals as a double boiler when making candles. I put my wax pot in the frying pan, fill with water, then melt my wax. I do not care of the pan gets wax on it because I no longer use it for cooking.
I also use larger frying pans pans with compromised seals under the car when I drain oil. I allow the oil to drip (provided it is less than 4 qts.) into a plastic milk container that I cut the top off of. I set the plastic container into a large frying pan that I no longer use. The handel on the pan makes it easy to slide out the plastic container once it is full of oil. I then take a funnel and transfer the oil into another milk jug or old 164 oz laundry detergent bottle that still has the threads for the plastic cover in tact. I mark it used oil and set it aside in the corner of the garage for when our community allows for the annual oil and chemical waste pick up.
My dad was an avid hunter...he used old frying pans for target practice when on the country land...he'd hang pans from the handel and shoot at the pans he hung.
Sorry this is the best I could do.
Being a mom that has gone though this enough times....I removed all my metal utensils from the drawer next to the stove with plastic ones hoping my kids would grab the closest which are now plastic that is heat tolerant.
Mar 20, 2011 | Microwave Ovens
Good day we are a company located in South Africa who specialise in cleaning hospital & well as food industry equipment We are urgently looking to source a non stick spray on coating application for...
Try Prestige Housewares. If they don't do it, perhaps they can put you onto someone who can. Otherwise send someone out to a shop like Boardman's, let them look around the frying pans etc and look for a local manufacturer.
Jan 28, 2011 | Microwave Ovens
I have an old Le Creuset 16cm frypan an food especially eggs stick to the bottom .Is there any thing I can do to fix this?
hope that helps
Jan 25, 2011 | Microwave Ovens
I have a black sticky residue on the non stick surface of my cooks essentials 12 inch frying pan. I can not clean it off and the non stick properties of the pan is gone, I think due to this surface...
Dec 18, 2010 | Microwave Ovens
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Jan 29, 2007 | GE JES1231 Microwave Oven
Microwave Ovens Logo
379 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
