Question about Honeywell Heating & Cooling
Lennox af11 85 fan was blowing cold air and i pressed the reset button and it fired up and worked now it's blowing cold again and the reset didn't ignite it ,i pressed the reset button about 12 times before i read not to puch it more than once(i have it shut off now,,,appreciate any idea as to the problem and fix,,,thanks
djnick989
  • 1067 Answers
SOURCE: 1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Posted on Jan 25, 2008
  • 2039 Answers
SOURCE: Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Posted on Nov 09, 2008
SOURCE: Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Posted on Dec 20, 2008
  • 252 Answers
SOURCE: my fridgidaire gas furnace is blowing cold air
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Posted on Mar 14, 2009
emissionwiz
  • 76649 Answers
SOURCE: AC not blowing cold air at times
poss causes are, sticking low pressure switch, defective Ac compressor clutch closing coil or incorrect clutch driven plate air gap, spec is 0.26 thousands.
Posted on May 11, 2009
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Oct 27, 2013 | Honeywell Power Humidifier: Furnace...
Lennox Elite air handler will run cold for a while, then it will blow warm air out until the safety switch is moved, then it will make a noise in the system which sounds like air hissing, then the cold air...
sounds like installer broke on yellow wire between thermostat and condenser. your switch is breaking the 24 volt signal to cobdensor when the internal float is activated. moving the switch is somehow allowing bobber to drop enough to reactivate 24 volt and condenser comes back on. refrigerant starts to recirculate again and thats what your hearing in the lines. the switch prevents evap coil pan from spilling over into your return when the drain is clogged. use a shop vac and clear your drain. i blow it out with compressed nitrigen. after line is clear prime it wuth 32 oz of water.
Aug 07, 2013 | Heating & Cooling
When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run...
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Jul 20, 2013 | Heating & Cooling
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
When heat on it makes a clicking sound then blows cold then clicks again then blows heat
Yah! I think you pressed mode button. If you press mode button it shows- Fan,Dry,Cool,Heat and Auto. You stop at your required mode.
Dec 12, 2010 | LG Heat cool Window Air Conditioner
I got a lennox xc13 air condtitioner,not blow cold air
When was the last time you checked or had the freon level checked.
Aug 02, 2009 | Heating & Cooling
Lennox air unit not blowing cold air
your fan motor outside is going bad, have a service company change it out for you.
the motor stopped working and that overheated the compressor shutting it down on thermal cutout, and it will only come on once it cools down
Jun 16, 2009 | Heating & Cooling
Lennox G40UH-60D-135-14 Furnace will not ignite
Do you have an inducer on the unit (no access to the lennox model number tonight)? That is a motor that comes on shortly before your unit fires that blows the combustion gases up through the flu. Does this motor come on at all if you have one? If it does and the furnace will not light, then there is a device on the unit called a pressure switch. This switch has two wires to it and a small tube that leaves it and goes to the inducer housing. Remove the tube from the inducer and blow into and draw in air lightly or until you hear clicking noises. Replace the hose and try again. Sometimes the pressure switch gets stuck but can also go bad. If everything is coming on all the way up to ignition but the unit won't come on, then it's probably one of the limit switches that need to be reset. These are little disks about the size of a penny and have two wires going to it. In the middle is a small button that can be pushed to reset it. Some units have 2 to 3 and others have more. You have to use a flash light and look all in the unit around the burners and around the flu pipe looking for the limits. Once you have found them all and tried to reset the unit, then try to start it up again. Hope this helps.
Apr 04, 2009 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
