Question about Coleman Heating & Cooling
I have a coleman 6727b707 air conditioner. I would like to know the starting and running amperage
  • Robert Apr 05, 2011
    Starting amps of compressor or motor?
  • garygdnr Apr 05, 2011
    I am trying to determine if a 2000w inverter generator will start and run this AC
SOURCE: Coleman RV air conditioner
It is not leaking. that is the condendensation it is pulling out of the air. It is suppose to leak on the roof and off the camper.
Posted on Jan 05, 2008
chillmaster
  • 104 Answers
SOURCE: i have a coleman evcon
R-22
Posted on Jun 23, 2008
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
  • 82 Answers
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Posted on Jun 28, 2009
carlsbiz
  • 1124 Answers
SOURCE: coleman 7300 rooftop air conditionor wont operate
When they sit allot - sometimes the fan will stick.. Take the cover off,, turn it on and see if the fan is stuck.. Spin it by hand to free it up..
Posted on Jul 09, 2009
I need a switch for a Coleman 6727B707?
Sorry we do not sell parts here nor do we have anyway to locate them for you.
Jun 23, 2017 | Coleman Heating & Cooling
Do i need to have propane to run my airconditioner?
Most Coleman air conditioners are ELECTRIC. I don't know of any propane air conditioners made by Coleman.
May 12, 2015 | Coleman Heating & Cooling
Suburban air conditioning
googled:
"suburban air conditioner 15000-48254C966" and got specs right here:
http://www.adventurerv.net/coleman-15000-btu-roof-air-conditioner-top-unit-p-1332.html
good luck.
Sep 03, 2014 | Electrical Supplies
Coleman AC Tripping breaker
Fan motor is drawing too much current.
May 16, 2013 | Heating & Cooling
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I have a coleman roof top air conditioner on my 2006 Jayco travel trailer. The air conditioner will start to run and the fan blow air but it doesn't want to cool down. Is there somehting I should do or...
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
Today the blower motor started running slowly,approx.half normal speed, both high and low setting,on our Coleman Mach 3 ac unit.I believe it is orig.in our '87 Hoilday Rambler.Any ideas would be much...
GO TO rvcomfort.com
Jul 26, 2010 | Coleman Mach III Air Conditioner
Model coleman mach 8333c8714 serie 8000 my a/c start for 2-3 minutes and than the a/c shut down but the fan still working!! after a few minutes , it want to start again but dont seem to be able to. you can...
GO TO rvcomfort.com
Jun 15, 2010 | Coleman Mach III Air Conditioner
Need solar panel monitor for coleman TSR
Wire it direct to batteries. It puts out very little amperage, so not to worry about overcharging the batteries. It's only basically a trickle charge.
Jul 10, 2009 | Coleman Mach 15 Air Conditioner
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
GO TO rvcomfort.com
Apr 20, 2009 | Coleman Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
