I have 2 wires coming out of the ceiling, i attacthed the white wire
from the ceiling with the white wire on the fan. Then i attached the
black/white and the black wire from the fan to the red wire in the
ceiling. When i try to flip the switch, the circuit breaker pops. Any
help would be appreciated
An expert that got 10 achievements.
An expert that got 5 achievements.
An expert whose answer got voted for 100 times.
Master
Re: Ceiling Fan Electric
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Black is the hot wire, white is the neutral, and blue is the hot wire for the lights. If you only have a black, white and green(ground) coming from the electric box in the ceiling, you will have to wire the blue and black together coming from the fan and connect them both to the black coming from the box. The white will connect to the white coming from the box in the ceiling. You should have a ground wire off of the fan. If not look for a ground screw on the fan down rod. The ground is for safety.
I have to assume a bit here. If you have 2 black and 2 white in the ceiling, then the proper way to connect would be . the white that is the run from the panel, the powedr white connects to the fan white ... the power black connects to the other white wire (put some black tape on that white wire) and the other black connects to the fan black .. if you hacve a meter you can test the wires and see which pair has the 120 volt power.
Please vote !!
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
