Question about Craftsman 25cc Gas Line Trimmer
I have a ST622 walk- behind string trimmer, a tank of gas lasted for 8mins and the air filter was soaked with gas and leaking. What could be the problem?
  • Craftsman Master
  • 7,482 Answers
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
String trimmer leaks fuel
the primer bulb could be your problem. easy to replace
Apr 06, 2017 | Garden
I have a st622 ariens walk behind What size is the string I should be using.
Your trimmer line is 18" in Length (46cm)
5/32" diameter (0.40cm). I'll give you a link to your owners manual that you can download and I hope that the link works. You may have to give some info to log into the site in order to get it; not sure, as I use the site quite often to download manuals and only had to do that the first time.
http://dl.owneriq.net/3/3f858f4f-0b60-49b5-a6f8-ec4a7a994de4.pdf
Best of luck to you.
James
Aug 11, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
String trimmer only runs with choke on
If you have to run with the choke on, it's having problems pulling gas thru the carb.
Start making sure that you're using fresh gas/oil mix. Don't attempt to use last years leftover in the tank or a spare can. Bad news... won't fire well.
Second, pop the carb lines off the carb and flush with carb spray cleaner (use the nozzle tube that comes with the can).
Third, check for cracks, breaks, leaks in the supply and return hoses. Replace any damaged hoses.
Disconnect the carb from the engine and spray all jets, orifices with carb cleaner (I like the Berryman's B-12 spray) and reinstall.
Also, pull the filter out of the air filter and clean, reinstall.
While you're at it, pop the spark plug out and clean the tip with carb spray as well.
Finally pour in a fresh gas/oil mix...start as usual. should be alot better!
Jul 02, 2009 | Ryobi Garden
Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
May 04, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
147 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
