Question about Franke Plumbing
Water flow has slowed to a trickle in our Franke pull out spout faucet just over oe year old. have disassembled to clean but found nothing worth while. have not taken spout apart for fear of damaging. help
  • 1 more comment
  • jmonhn Apr 06, 2011
    sorry - we cleaned all the way back and did check supply tubes also - nothing.
    Doesn'g fix our problem
    jm
    needless to say "not what we wanted to hear". Very much appreciate your being upfront with us - does this also mean we can expect a refund of our $18 to apply to new faucet? and yes, probably not be a Franke.
    tjs
    Joyce M
  • jmonhn Apr 07, 2011
    ffps200
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
This is not an answer yet so please do not rate the post at this time. I need to know which of these models you have to better help you:
http://www.frankeksd.com/productgroup.php?group=7&node=11&lvl=0
After you respond with your model number I will respond again.
Thanks for choosing FixYa,
Kelly
Posted on Apr 06, 2011
  • 1 more comment
  • Kelly
    Kelly Apr 07, 2011
    Most of these pull out hand sprayer units have a screen in the hose that goes from the sink connection to the spray head. Disconnect both ends of the hose and look for a mini-plastic in line screen / strainer and then clean the screen / strainer under running water in another sink. Test the water flow before you reconnet the pull out spray head by re-attaching the hose to the faucett assembly to make sure you have corrected the problem.
    If after cleaning the sprayer head you still have slow water flow, turn off the water supply and disconnect the plumbing connection to the control handle. Get a bucket and test the flow there for BOTH hoses. If you still do not have good flow then there is something in the house plumbing / wall connection at the water shut off valve. The water valves used in under the sink plumbing are not always of good quality and a small piece of debris in a wall connection can make a HUGE difference in the volume of water that can pass through a wall connection shut off valve. If you are having restricted flow from the wall connection to the sink faucett connection change the wall connection shut off valve.
    Kelly
  • Kelly
    Kelly Apr 07, 2011
    After reading everything that you have done.....
    I suspect that there is debris in either item 17 or 24 this link:
    http://www.frankeksd.com/grfx/pdf_files/...
    The check valves.
    Kelly
  • Kelly
    Kelly Apr 07, 2011
    This faucett comes with a limited 5 year warranty. (See Faucetts)
    http://www.frankeconsumerproducts.com/wa...
    The phone number is 1-800-626-5771
    I would at least make the call and see what they tell you.
    Kelly
  • 43,501 Answers
The dirt gets caught in the faucet before the spout of the valve...
The only way to clear the dirt out is to take off the supply tubes and then using an air compressor, blow air backwards through the faucet the blow the dirt back out the supply tubes...
heatman101
Posted on Apr 05, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Apr 06, 2011
    You will not see anything and if you have not purged with a good shot of compressed air backwards through it then you will not have it cleaned out completely...
    Even so I have had times when the dirt is lodged so tightly that a complete replacement was necessary...there are very small passageways in there that cannot be accessed with out ruining the faucet...
    Yes!!! very poor design....I agree!!!
    heatman01
Will replacing a cartridge in my Jado Glance single lever bathroom faucet make the water flow again? It's down to a trickle!
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
Dec 18, 2014 | Jado Plumbing
How to access O-rings? (Faucet won't pivot)
You'll have to turn off the water using the shutoffs or if there are none by turning off the main. open a faucet on the lower floor of the home to remove most of the water out of the system if you have to shut the main. using an allen key remove the handle. then using an adjustable wrench or crescent wrench or as a last resort a set of channel locks remove the big nut at the top of the faucet and remove the stainless steel ball assembly. You'll have to undo the hose going to the faucet from under the counter and pull the spray attachment out. Then wiggle and pull up on the spout to slide it off. Clean any lime deposits with CLR or any other descaler. You can scrape some of it off with a knife if you must. When both the spout and the shaft where it is to slide onto are both clean remove the old o-rings, replace with the new ones. Slide the spout back on. You can grease the o-rings with plumbers grease to help seal them but also to help slide on the spout easier. You can replace the seals and springs inside where the stainless steel ball goes if you please. Reassemble everything. Turn on the water. Remove and clean the aerator of any debris (done every time you do plumbing) Test that the faucet moves from side to side without leaking. Different models may have different procedures and or different o-rings in different locations. Do what you must to change the o-ring that needs changing.
Nov 17, 2013 | Kohler Model 10433: Fort® Single-control...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
The swing mixer handle has become very stiff. how do i get it off to clean it/
The first solution is of course correct. However I found it almost impossible to remove the spout assembly. It was very stiff and it was difficult to get any leverage to force it off without damaging the finish to the tap as a whole or damaging the sink.
What I found was that if you poured boiling water over the tap/faucet it eased the stiffness and having done this several times - ie about 5 kettle loads of hot water, I managed to remove the spout. It helps if you reconnect the hose directly to the outlet under the sink (ie not via the faucet). THis allows you to run cold water through the tap whilst pourung boiling water over the outside of the tap. The cold water shrinks the copper/brass components whilst the hot water expands the spout assembly.
Once off, it is possible to clean the inside of the assembly to remove corrosion or calcium deposits to say nothing of old "O" rings.
I also used a kettle descaler between dousing with boiling water in the hope that some of it would seep down within the assembly.
It took me three attempts to do this. I was almost going to spend UK pounds 430 or US dollars 670 and buy a new unit. So do not give up and I hope this helps.
It swings backward and forward now perfectly.
Aug 27, 2010 | Blanco Classic Single Handle Faucet with...
My faucet is barely letting water out. This problem happend over the last couple weeks gradually and now there is hardly any pressure for the water to come out. I have tried to soak the fauset head in...
If you have checked the head then that is ruled out. I assume that all the other faucets in the house are okay. The problem is in the small passageways inside the faucet, if both the hot and cold are slow then it is probably in the one going to the spout. If you remove the heandle you can often pull the spout up and over the guts of the faucet. Check for an obstruction in the hole going to the spout. Also blow out the spout to make sure that it is free of debris.
Very small amounts of debris can make a faucet very slow.
Nov 13, 2009 | Kohler K-12176-PB Fairfax Single Handle...
I have the PP Marielle Kitchen Faucet with spray and soap. My water pressure is extremely low. I tried to go online for guide to show me how to fix valve and where it is located but site tells me my model...
you have dirt in the deverter valve its in the fachet part under the sink turn off the water remove the spring it slides out then pull the devert out clean the parts and reinstall i have 3 of them doing the same about 6 mounts old a bad fachet desigen
Aug 19, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water pressure became slow after less than 6 months of a new Moen Kitchen. Faucet some calcium build. Pressure is the same with both hot and cold running. Makes me think it is the faucet.
It is probably a clogged airator. If the faucet is the type where the spout is attatched to a hose there may be a screen where the hose attaches to the spout. with the spout off check the flow through the hose. If the flow at the hose is good then the problem is in the spout. Most of the time it is in the spout. you can replace just the spout if you cannot find a screen or airator to clean.
Jun 16, 2009 | Moen 7786SL Monticello Two-Handle High Arc...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Water trickles out of sprayer head on pull out faucet.
Hi crossroadsjm,
I'm Harvey the Master Plumber.
Your problem is: soaked in vinegar water but did nothing. took off spray head from hose and the water stream is very small in diameter. only 1 year old faucet. could cartidge be bad or clogged? water pressure in rest of house is fine.
It is very possible that some debrie has come up in the water and is partially clogging the faucit. For this you would have to turn the water off and disassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 14, 2008 | Price Pfister 532-7PCC Marielle Pull-Out...
Plumbing Logo
361 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
