Question about Microwave Ovens
We own a Bravetti 7 Quart Oval Slow Cooker - Model #KC271B. One of the handles has come off - it appears to have melted the plastic that the screws attach to. How do we get a replacement handle?
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Spacemaker 1800 Handle Base Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 06, 2007
myob247
  • 1342 Answers
SOURCE: Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Posted on Jun 01, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Dacor PMOR30S 2001
We have the service manual and parts listfor this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
Once you have any needed part numbers, the most affordable parts source is
here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: Repalce Door handle on GE Profile model number SCA1000DBB03
There're some half a dozen or so small screws securing that frame to the door face. These screws must be removed. Then, the frame can be pried out by releasing the plastic snappers (with a flat screwdriver) while in the same time gently helping the frame to detach from these snappers' hold and the door face. It's a tidious, somewhat annoying task. The snappers may and will even likely break in the process, but aren't needed for the frame to be resecured to the door face after the handle is replaced. Note that the broken ends of the handle must be held with a pair of pliers or a flat screwdriver needs to be inserted bewteen each of them and the hole, or the ends will turn with the screws. This is because the metal screws' grip of the plastic handle broken ends is very strong and will otherwise won't get separated.Once the above is accomplished, reassembling the door is a brease.
P.S.: The dual end latch may interfere somewhat with the job and can be removed for the prtocess to be undertaken without it disturbing. It's easy to remove and replace that latch, including its spring.
Posted on May 12, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: How to replace cracked plastic door frame on Whirlpool microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 20, 2009
Can I put the lid of my slow cooker in the oven? I'm cooking conventionally using just the crock. Val
I wouldn't recommend it as the lid has a plastic handle which will melt. The covers
themselves are made of pyrex glass generally and would stand the heat, It is just
a concern as to what material is attached to them as far as knobs and trim ring.
Hope this helps.
Jun 05, 2011 | Microwave Ovens
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL1800 Microwave Model # JVM1870SF001
(I also replied via e-mail)
Sorry, but the subject lines get cut off after so many characters.
Thanks for replying.
Part # DE63-00204A looks like a valid Samsung part number but it doesn't show up anywhere, so it's likely a proprietary part made only for GE and not available separately.
You can see a helpful exploded view of this model here.
Then you can go here and enter your model number and come up with the parts list. This site has much better prices than GE.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Chances are you will end up having to but more than you want to, but not the whole door.
Sep 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave door handle replacement
Solution for GE Spacemaker Ovens (my model is JVM1650BH05)
1- Remove door by lifting it out of hinges. You will need to remove grille first (2 set screws).
2- Carefully pry off the plastic inside door trim. Use a fine knife or putty knife. There are 10 tabs holding the trim from behind. It's OK if you break a tab! Try to pull out as straight as possible.
3- Once the trim is off, remove the 2 visible screws that hold the door handle. NOTE: There are 2 invisible screws so you are not done yet!
4- You now need to remove the metal ring that holds the latches. To do that, grab the metal ring and using your other hand, release each plastic tab one by one (same tabs as above).
5- Once the metal ring is loose, you will see 2 screws. Remove them if they are still there.
6- Position your new handle and attach using the first 2 screws.
7- Reposition the metal ring by re-snapping it in place. Install the other 2 screws.
8- Replace the plastic trim by snapping it back in place
9- Reinstall door and grille. Tell wife or hubby that you are a genius!
Bonus: use metal washers when screwing down the 2 first screws.
Mar 10, 2008 | Microwave Ovens
BROKEN HANDLE FOR GE MODEL JVM1340WW002
Odd that we both have the same problem on the same model and same day..
If it's completely broken off, then you have probably pulled the threads out of the cheap plastic,, there are two screws that hold the handle on, one is easy to find/see, on the inside of the door, upper left corner,, to find the other, you need to remove (gently/carefully) the plastic bezel,, (all of this stuff is on the inside of the door), tap on it to find the plastic part,(bezel) and gently remove it by prying,, "prying" is an ugly word,, but since it snaps in, I'm not sure how else to tell you how to do it,, (Just go slow)
Once the bezel is removed, you can get to the other screw,
Now you have both screws, and know where they are supposed to fit later,,
On the back of the handle, the part that goes against the door, there are "studs" (plastic posts about 1/2 inch long and about the size of a pencil),, look closely into hole in the mounting stud, and you will probably see where the plastic threads have pulled out,, If thats the case,, the fun starts,,,
Go to lowes, or Home depot, and buy the smallest bottle of "Loctite" brand epoxy you can find,,
Look closely and the box will say something like,, "SETS IN 5 MIN.", or so,, get the LONGEST setting epoxy that they have,,
Now your back home and drinking a cold beer,, and ready for fun,, ---,Spray the screws with "non-stick" cooking spray, and set aside, (but handy)
Next,, match the handle back up to the door,, and identify which is the top,, mark it,, (masking tape and magic marker),,
I know it sounds silly, but you don't want to be fumbling around with it, while the epoxy runs back out of the holes and all over everything,, set the handle aside, but handy,,
Follow the instructions on the box, to mix the epoxy,, (work quickly)
Now,, using a toothpick or something similar,(disposable) dribble the mixed epoxy into the holes, (where the screws need to go), you don't need to fill them up, but a good 5 drops or so at least,,, WORK QUICK,,, remember to put it in both holes,,
Get ready to mate it back to the door, handle in one hand, a screw in the other,,
Top on top,, and from the front,,put the studs into the two holes
and as quick as you can, insert the screws,, you probably won't need to screw them in, (Threads are stripped out), but you may,, if so, just barely tighten them, just enough to "seat them, and the handle to the door,, It would be best to tape the handle in place until the epoxy sets,,
Check for ozzing,, dribbles, and drops,, and wipe it up now,, or it will be there forever,,
Sit back, put feet up, drink the rest of the beer, and watch epoxy dry,,, (Wait an hour to be safe) Besides, it gives ya more time to drink some more beer,,
Thats my best guess on how to re-attach the handle,, But I'm waiting until tomorrow to do it,, (out of beer)
Best of luck, Ted
Jan 08, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
