Question about Kitchen Ranges
What does the F7 error on my Kenmore Electric stove top mean? The oven is still working. Thanks!
  • 17,970 Answers
F7 on that make of range usually indicates a problem in the control keypad in which case on your model the whole console panel usually needs to be replaced to correct the condition. First time it shows, turning off power to owen worked fine. It showed up a couple times and now turning off power didn't work. And the touch panel stop functioning altogether.
A permanent fix for this problem was developed by Charlie Popeck, a professional engineer. It involves inserting a piece of paper between two ribbon cables to eliminate the possibility of short circuit between the two cables. The 30 minute procedure is described (including photos) at the web site: dreaded_f7_error
Hope helps.
Posted on Apr 05, 2011
F7 keeps beeping on my electric slide in range model #911.4658813- stove top works but oven will not operate as everytime I turn off electricity and on again the F7 comes back on
Hi
Error code F7 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | Kenmore Kitchen Ranges
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
What is code F7
Hi
Thanks for using FixYa. Error F7 on your range means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | Kenmore 48385 Electric Triple Oven
Oven keeps blinking F7 AND WILL NOT WORK
Hi
Thanks for using FixYa. Error F7 on your Kenmore means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 15, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Giving an F7 error code
There was a tag on stove that told on the error codes. Reset pad, it was somehow stuck. Thank you for your help!!
Cheryl
May 27, 2009 | GE JRP15 Electric Single Oven
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F7 Code on the Stove Top Burner
Hi hyaeron and picksi66
Happy to help you!!
This means,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Jul 07, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Sep 30, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
