Question about Tannoy Fusion TS10 Speaker
My Tannoy TS10 Subwoofer is only making a humming sound and not working properly. It was working for several years and then the humming. No changes to connections or receiver. Is there a fuse I should check or some other course of action you can recommend.
  • kcdoogie Apr 05, 2011
    Ya, I figured that out. My bad. Probably a bad preamp.
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 65 Answers
This can be coused by a bad capasitor. Try and heat up the amp module. Sometimes it will worked when capasistor are heated up.There are typical problems with C208 on pre-amp module and C100 (sometimes C101) on power amp module. If the hum is loud check also the larger cap in power.
Posted on Jan 19, 2016
    Problem Solver:
  • 15 Answers
If you have a hum, then your fuse is ok.
Posted on Apr 05, 2011
    Ya, I figured that out. Probably a bad preamp.
  • pro-tech Apr 06, 2011
    when you say "not working properly" you have to be more specific.
    normally amp and pre-amp stages are on the same chip-pack like enclosure. (i.e STK404-180S) just look for your pack and pack number and replace it.
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How do I replace a fuse in the Tannoy TS10 Subwoofer
The fuse is located under the AC input cable. Pull out the cable and you'll see there is a slot that will fitt a flat screwdriver. Pull this out and you'll find the fuse.
Jul 21, 2012 | Tannoy Fusion TS10 Speaker
My Tannoy TS10 keeps blowing fuses and I get no power signal on the LED
Something inside it is acting like it was just a piece of wire instead of doing it's job. That's why the fuses blow. Look at either the power supply section - transformer, diodes, voltage regulators. OR the main output devices. If they are transistors, you can test them with a ohm meter. The part will show up easy! It will be just like you had just touched the two probes together!!
Mar 20, 2010 | Tannoy Fusion TS10 Speaker
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Anybody has any information about Tannoy Puma speakers
sure. what do you want to know?
cathy@speakerex.com
Jun 08, 2009 | Tannoy Fusion TS10 Speaker
No signal on subwoofer out in Onkyo TX-SR703(E) - similar to TX-SR803
Hey Tad, I have the same problem and perhaps a solution. I just moved to the other SW "pre-out" and it seems to be working..the green light is on . Whatever works i guess.
Jan 24, 2008 | Onkyo TX-SR703 Receiver
Power Problem Tannoy TS10
Have you checked the power supply. Maybe it has died.
Oct 22, 2007 | Tannoy Fusion TS10 Speaker
Tannoy Fusion TS10 Speaker Logo
622 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Rommel Balcita
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
