Question about Amana ARB1917CSR Bottom Freezer Refrigerator
Amana ARB1917CSR ? Refrigerator freezing food, (bottom) freezer working OK
The entire refrigerator compartment is now freezing everything, whether vegetables in that compartment or water bottles on the top shelf. I sure would appreciate some suggestions and here is what I’ve tried so far.
-- Per the manual’s instructions found that my freezer temp is OK (0-2 F) and thoroughly cleaned the coils (vacuum + garden leaf blower blow-through with front and rear grills removed), but this made no difference.
-- Others on this forum have mentioned possible “damper control problems”, i.e. damper stuck on open and too much cold air from the bottom freezer migrating to the upper refrigerator compartment. Where is this damper located and how can I check it or poke at it to see if it will get back working again? Someone else mentioned taping the duct opening part way, does this work as a last resort?
-- Had this same problem when the refrigerator was delivered new in Aug ’02, and upon a fight with the dealer got the thermostat replaced under warranty. Well, that worked for a while and now the warranty has expired. And in the remote area of the home where this refrigerator is located the appliance dealer (only one available) is known to charge for changing parts, whether or not it solves the problem. I sure would appreciate some help!
  • 2 more comments
  • Tom Rodriguez Aug 06, 2008
    Rickzila,
    Thank you for such fast and helpful response. Next week I'll be back at the second home where this refrigerator is located and upon following your suggestions I promise to post my findings. Indeed, I have yet to examine just how the cold air flows up from the lower freezer compartment to the refrigerator chamber above, or the damper mechanism that must be there somewhere.
    Regarding a thermostat failure within 6 years, given it had to replaced (under warranty) within days of this new/expensive refrigerator being delivered, I consider this product to be a LEMON and will NEVER buy an AMANA product again (also no troubleshooting customer support). On the other hand, as I understand they were taken over by Whirlpool and their washer/dryers last forever. (Mine are 17, 17 and 34 years old and still going strong.) Thanks!
  • Geigz Oct 22, 2008
    Our fridge does the same thing. The two veggie drawers are constantly freezing the veggies... which is quite annoying. I like the fridge cold but seriously... that's too much. I'm going to try the duct tape thing but any other recommendations would be greatly appreciated.
  • deeva2di4 Oct 25, 2008
    Warranty on my Amana just ran out 3 days ago - my repairman had been out just over a month ago, more than 30 days, so his previous work is no longer covered under warranty, as I found out 3 days to late!!
    I've had continuous problems with this Amana (bottom freezer) - the most recent being vegetable drawer freezing.  The repairman plugged a cold air circulation hole somewhere behind the 'Chef's Pantry' drawer.  That apparently did NOT solve the veggie freezing, or the 'pantry' drawer freezing.
    What if we appeal to the now owner/manufacturer - maybe they would prorate something. This Amana is SUCH A LEMON!!!
  • lori kapustik Sep 04, 2013
    differnt model by just a few numbers, but mine is also freezing
  • 706 Answers
I picked up on something you wrote within your problem description. "got the thermostat replaced under warranty" & "that worked for a while ". back in Aug of 2002. It's August of 2008 and your thermostat may have failed again. 6 years later... not so unusual. Anyway, since your fridge has a bottom freezer, there must be a pass thru between the freezer and the fridge compartment in an area you haven't examined yet. The fridge gets cold air delivered from the freezer to keep it cold thru this pass thru and many fridges have an adjustable flap that allows you to limit that cold air flow. Time permitting, can you do a more thorough examination of the fridge area ( side walls near crisper drawers perhaps?) or better than that, remove the drawers and look for that air duct pass thru. Once located, if it does not have an adjustable damper, try a little duct tape to limit the amount of cold air from migrating into the fridge compartment. Other options: Can you contact Amana customer support directly and get their support? That particular model has been discontinued by Amana but they should be able to support it. Not sure I added anything to what you already know. Gave it a shot thou...
Posted on Aug 06, 2008
Freezer is not freezing and fridge is barely cold
sounds like the ptc relay/ overload on the compressors bad
Aug 07, 2011 | Amana ARB1917CSR Bottom Freezer...
The refrigerator often freeze food at the rear of fridge. Have a buzzing sound follow by a click which last for a few seconds. The bottom freezer stopped working, started again and is not freezing now
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Amana ARB1917CSR Bottom Freezer...
Amana ARB1917CB bottom freezer refrigerator, not freezing at all has done this before but have always manage to get it working again top & bottom up as high as it can go, but the top doesnt feel that...
YOUR COMPRESSOR MAY HAVE FAILED. USUALLY ABOUT 800 TO REPAIR. THERE MAYBE A FIVE YEAR FULL WARRANTY ON THAT. OR EVEN A 10 PART ONLY WARRANTY. CHECK MODEL AND SERIAL NUMBER HERE TO SEE. http://servicematters.com/warranty/warranty_main.htm
Apr 23, 2010 | Amana ARB1917CSR Bottom Freezer...
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Amana abb1922few bottom freezer refrigerator freezes in the ref section freezer ok
Good day,
The air going to the fresh food compartment is controlled by a pneumatic damper which varies the amount of air going to the food compartment. Many times it pops the spring off that tries to keep the flap open. It is located at the top rear. Look here.
If it proves to check out ok. (I'd take it to an appliance parts house to let them see it,) it would be the control that regulates it's opening position.
Apr 09, 2010 | Amana ABB1927DE Bottom Freezer...
Amana arb1917cc fridge not cooling no sounds from it at all light is on how do i fix this problem ?
Good day,
If the lights work, and nothing at all is running, then it is either the defrost timer stuck in defrost, or the main thermostat in the freezer compartment has failed.
Check the timer first. With the freezer control in the freezer compartment set to at least 4 or higher, look for a small hole in the fresh food compartment. It is in the roof (top) of the compartment almost half way back.
With a small screw driver, turn the shaft of the timer clockwise at least a 1/4 of a turn. If it starts, then the timer is bad and needs replaced.
If no luck then it would be the thermostat in the freezer compartment that failed.
P.S. As with all machines, a broken wire could be the problem but on your model, is extremely rare.
Dec 13, 2009 | Amana ARB1917CSR Bottom Freezer...
Defrost not working
Since you've determined the heater is good, check the following items: Defrost timer in fresh food compartment (may not be advancing or the contacts may not be changing from open to close or vice versa), defrost terminator secured to the evaporator (may not sense a rising temperature)
Exploded parts diagram for your fridge:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167592
Generic service manual for Amana bottom mount freezer / fridges:
http://www.servicematters.com/maytag_library/docs/S120_0R0.pdf
http://www.servicematters.com/maytag_library/docs/T120_0R0.pdf
I hope this helps!
Sep 28, 2009 | Amana ARB1917CSR Bottom Freezer...
The freezer on my Amana ARB1917CB keeps frosting over; the fridge no longer cools. The advice given on most forums for this siutation is to "test the defrost timer by turning the screw with a screwdriver,"...
I understand your frustration. Below are some diagrams and troublshooting aids. If you look at the exploded parts diagram link and select the Wiring Information page, you'll see the defrost timer is on the FF harness, which is the "Fresh Food" compartment.
Next, click in the "Controls" page. Item #12 is the defrost timer. It looks like it is in light assembly / cover in the fresh food compartment as it has 2 light bulbs shown - and the freezer has only 1.
I hope this helps!
Jun 24, 2009 | Amana ARB1917CSR Bottom Freezer...
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
1,507 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
