Question about Whirlpool Duet Sport HT WFW8400TE Washer
My washing machine was blinking code "F20" what
  • 5,911 Answers
"F20" is a "No Water Detect" error code. This usually means you have very little water entering the machine, or no water at all. The following link explains the error code in more detail and steps necessary to troubleshoot:
http://www.fixya.com/support/r3608632-f20_error_code
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: Each one of thes washers comes with a technical data sheet inside. The tech sheet lists all error codes, troubleshooting information, wiring diagrams, diagnostics procedures and illustrations. To access, you need to remove the lower toe panel directly below the door. The screws are located under the bottom front edge. With the screws removed, the panel will drop down and can be removed. If the tech sheet is not located directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
I mention the tech sheet, because you may need to refer to it in order to accurately troubleshoot
Posted on Apr 05, 2011
F20 error code on maytag epic any idea what this means?
F20 means that the unit isn't detecting water is entering the machine quick enough. When the error code appears if there is little to no water in the tub, then you have an issue with either the water supply to the washing machine or the electronic water valve. If the washing machine fills up about 1/2 way up the door and is overfilling with the water, it means that your pressure switch is faulty and will need to be replaced because it's not detecting that water is entering the machine.
Mar 02, 2015 | Maytag EPICz 3.7 cu. ft. Washer
Showing code F 20
f20 code means no water is entering the machine. make sure your water hoses are connected properly and that the water is turned on. could also be a problem with your pressure switch.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We do not know what the f20 code means
F20 No water detected entering machine, defective flow meter, clogged water valve inlet screens, unpaid water bill. themobilian_1148.jpgthemobilian_1149.jpgthemobilian_1150.jpg
Duet service manual and more HERE
Jan 30, 2011 | Washing Machines
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine has a trouble code showing,the code is "F20",what does this mean?
F20= flow meter, they sense the 'flow', if no flow after a certain amount of time it errs out, replace the sensor, it is erratic. Tell your tech he can replace it or get a 'recall'
Oct 23, 2009 | Kenmore Elite 45986 Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
F20 code.
in my fixing f 20 needs a new cpu main board in the top washer middle back side
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Sport HT WFW8400TE Washer Logo
379 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
