Question about VeriFone PINPad 1000SE Network Terminal
On my Verifone 10008E----ERR - No DKEY - VeriFone PINPad 1000SE Network Terminal
Gettin no Dkey error
your pinpad probably not loaded with the right encryption. call your processor. thanks
Sep 12, 2011 | VeriFone PINPad 1000SE Network Terminal
I need a download for an operations manual for a verifone vx610
The link below should be what you need.
http://office.manualsonline.com/manuals/mfg/verifone/vx_610.html
Mar 17, 2011 | VeriFone VX 610 Credit Card Terminal...
Verifone vx 510 download needed no*go variable analog line
www.verifone.com/.../23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
www.verifone.com/PDF/Vx510_Merchant_US.pdf
Above are your manuals, below is the Verifone website, use the support link to contact them, and ask for whatever you need.
http://www.verifone.com/technical-support.aspx
below is the USB driver.
http://verifone-usb-driver-installer.software.informer.com/3.0/
Dec 17, 2010 | Office Equipment & Supplies
Drivers for a verifone 250 printer in winxp
You can try to find it at this link
http://verifone.50webs.com/
Dec 18, 2008 | VeriFone 900 Matrix Printer
Pinpad won't work, but has worked before.
The encryption that is loaded on the pin pad is wiped out; this may have happened when powering off the terminal, unplugging the pin pad without unplugging the terminal power source first. What you would have to find out is what platform you are on from your processor, if they are not willing to do it, you can contact companies that will reprogram your pin pad. This will be cheaper than to buy another pin pad.
Dec 12, 2008 | VeriFone PINPad 1000SE Network Terminal
"Programming Err 0"
The error message "Programming Err 0" means that the terminal memory has been corrupted. The only way forward is to acknowledge the situation and reload the terminal application.
If you press the [1] and [FUNC/ENTER] key at the same time, oten the message will go away. However, you will have a terminal with no programming in it. You will need to call your processing company and get a new load.
David
Prairie Trail Software, Inc.
Providing applications and hosting solutions for Tranz terminals and web based transactions
Jun 29, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
Verifone 1000 se
The Verifone 1000se uses a special serial cable that also has to provide power to the device. It does not use either ethernet nor usb.
Mar 31, 2008 | VeriFone PINPad 1000SE Network Terminal
VeriFone PINPad 1000SE Network Terminal Logo
294 people viewed this question
Top VeriFone Computers & Internet Experts
Martyn01202
Martyn01202
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
