Question about ASUS P5KPL-AM SE Motherboard
Sound and camera not performing - ASUS P5KPL-AM SE Motherboard
  • 961 Answers
Http://support.asus.com/download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22&os=29&hashedid=7lA7ukHVu9DpMqHh
If you need drivers you can get them here. You have Intel chipsets and Realtek sound.
For your Intel chipsets you can go here;
http://downloadcenter.intel.com/
If you click on "run Intel Driver Update Utility", Intel will scan your system and advise and provide updates for Intel products.
Are you having a problem with the cameras sofware? If it USB, plug it in then, click on "start", then
"control panel". Find and click on "device manager", open and click on continue. Click on the box next to "Human Interface Devices". Do you see a warning,?, !, or yellow triangle. click on that and follow proceedure. You should see your camera in the drop down. Right click on it and you should see "disable". If you see "enable", click on that and exit. If you have an install cd for your camera you may want to reinstall the software.
Posted on Apr 05, 2011
  • David Petry Apr 05, 2011
    You also may want to try a different USB port. If your using the ones on front, try one on back. If this works you may want to get back into device manager and look at "IDE ATA/... and look for a warning.
Does the vivitar vivicam XX14v2 record sound? I recorded a video and I couldn't hear any sound. Please help
Here is the manual for the camera. I am thinking that you probably have to play video on the computer or something with speakers to get sound. Having said that, I don't see a microphone on the front of the camera. It is a digital camera that ALSO takes video, not a dedicated Video Camera.
Havingsaid that, I just did a search of the manual for 'sound'. I found this
Silent Mode Menu
You have the option of activating the camera's 'Silent Mode' to disable all of the sound effects (except for beeps heard during the Self-Timer countdown) that the camera emits when performing camera functions.
Note: This does not affect the sound during video recording.
https://static.bhphotovideo.com/lit_files/289137.pdf
Nov 23, 2016 | Vivitar Cameras
When i am using canon ixus 105 in auto mode than there is a sound coming from camera and the display automatically switched off after 1 minute.plz solve this problem
Hello Swadesh,
Pressing the DISP button while turning on the camera power will turn off all sounds except warning sounds. To turn the sounds on , press the MENU button, choose the ii tab, and then choose mute. Press the <> buttons to choose off.
Confirm that battery is not depleted.
Confirm that battery is properly inserted.
Confirm that battery/memory card cover is securely closed.
If the battery terminals are dirty , battery performance will decrease. Clean the battery terminals and reinsert the battery again many times.
Jun 22, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Sound and picture jumping
This is probably because this camera records in HD format which will jump around when played on computers that are not very high performance. You need at least 2gb of RAM and a decent processor.
Otherwise, the codec is missing or old for playing the format.
Nov 19, 2009 | Canon PowerShot SX 200 IS Digital Camera
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Took video with it but no sound
I browsed the Instruction Manual of your Kodak EasyShare C310 Digital Camera on the internet and I found out that your camera really does not save sounds when recording video. It doesnt have that feature. Hope it helps. You can check it too in Performance Features - Video Formats in this site --- "http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7150/7096&pq-locale=en_US"
Jun 03, 2009 | Kodak EasyShare C310 Digital Camera
Video sound
hi there
the sound is being recorded but the camera cannot play it back as it has no speaker.
if the camera is connected to a t.v. it will play with sound.
the only exception to this is some zoom modes will disable the sound when used.
hope this helps
beergut707
Oct 26, 2008 | Olympus Camedia C-765 Digital Camera
Kodak Easy Share Camera My baby accidentally dropped it on the floor.Zoom won't
Hey pooda2,
It does sound like there is damage to your lens. Manufacturers’ warranty does not cover damage but a Best Buy™ performance service plan with accidental damage and handling would cover the repair. To find out if you have a performance service plan with adh on the camera you should call 1-888bestbuy. If you do have the plan you could bring your camera to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. If you don't have a performance service plan with adh on it you could still have it sent out to get an estimate on how much it would cost to repair it, but often with digital cameras the cost of the repair exceeds the value of the camera.
Sincerely,
Allan
Go Ahead. Use Us.
May 10, 2008 | Cameras
Camera not taking pictures
Sounds like you might have a lens error developing. Look for error messages on the screen. A clue is abnormal performance by the lens in tracking and zooming in and out.
May 06, 2008 | Canon PowerShot SD1000 Digital Camera
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
Camera stops shooting by itself
if its sound is beeping, it means the mechanism have an error. Check the small fuse of the power supply
Jun 03, 2007 | Canon ZR200 Mini DV Digital Camcorder
ASUS P5KPL-AM SE Motherboard Logo
149 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
