Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Do I have to reprogram my lock after changing the battery?
  • 963 Answers
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Posted on Apr 10, 2011
Change the battery in my 2007 Hyundai Sonata and now my radio won't work how do I get a code and put it in?
Hyundai Tiburon Questions - how do i reprogram my lock ...
www.cargurus.com > Questions > Hyundai > Tiburon
CarGurusAug 17, 2009 - how do i reprogram my lock remote to my car? i changed my battery an ... i change my battery an now my lock an un lock buttons dont wor. ... I have aHyundai 2003 Tiburon, and the following worked for me, get in your ... The unlock codeis inside the case. ... Now my radio interior lights and clock wont work.
Hyundai replaced car battery now radio doesn t Cars ... - Fixya
www.fixya.com > ... > Cars & Trucks
Hyundai cars & trucks replaced car battery now radio doesn t questions and answers ... replaced my battery,, now key remote radio & clock does not work.. thank you ... ...car If you didn't do this before you replaced the battery, then there is another code ... I put a new battery in my 2003 sonata and now the radio doesn't work.
Jan 06, 2016 | Hyundai Cars & Trucks
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
Inidcator light is flashing read and I need to change the battery. Are there any special instruction to doing that and do I need to reprogram the lock code after that? Thanks...
According to the installation instructions, you should not have to reprogram the lock after changing batteries.
At any rate, here is a great link where you will find videos and instructions for Schlage locks:
This link will take you to the page you need, to get started:
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
May 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
Changed battery and lost program cant find manual need reprogram 4 number code
changed the battery and lost the manual, put my code in and it worked , latter it started to beep and now it doesn't work... respond at all ....help thanks
Apr 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How to change batteries
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The instructions for changing the batteries and reprogramming the code can be found there. Good luck!!
Mar 19, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
My remote in my keys no longer work to unlock my doors or trunk. I have changed the batteries in the keys, the light blinks when I push it. What could be wrong? I have a 2001 GS300
Most likely: You have to now "reprogram"your key fob and car to recognize each other. Look in your User's Manual for the car or, if it's an aftermarket fob/lock system, look in the user's manual for that. If there's nothing about battery replacement/reprogramming procedures, and it's a factory system, head into a dealer to reprogram it. It could run you up to $120, but that's cheaper than buying a new fob or system. If it's and aftermarket system and the manual says nothing, go to the place you had it installed (repair facility, Future Shop, etc) and have them reprogram it. If they installed it, they should know how to reprogram it.
Keep in mind, that's only the most likely option. Another possibility is that the receiver in the car, transmitter in the remote, or lock actuators/relays, etc in the car are the issue. It may not have been batteries in the first place at all. That said, it was most likely the batteries, and your best bet is trying to figure out how to reprogram the fob and car to recognize each other.
Jul 10, 2009 | 2001 Lexus Gs 300
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
698 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
