Question about Pioneer Audio Players & Recorders
My VSX 517 amp's sound is outputted before the vision on the TV. The sound seems to be anything up to half a second ahead, it is not always out it depends on how long someone is speaking for, plus which sky channel I am watching seems to make a difference too. One thing that is really confusing is if someone is talking in shot and sound goes out if camera pans away then back whilst they are talking it is then back in sync until a few seconds has passed then it is out again
    Brigadier General:
  • 8,546 Answers
Lip Sync issues are the nature of the beast. The TV has to process the digital video bitstream a lot more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. You didn't name yours so one does not know. I don't think this unit has that function. Look in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-517-S-Receivers-manual/id/2526bh740/t/2/
Posted on Apr 05, 2011
  • kingy_67 Apr 06, 2011
    Thanks for the info Dunnbiker very helpful. I do not think my amp does have the delay timer but will look. I agree in the fact that video takes longer to process, something worryng me is that the processor int he new TV I have bought is slow, as I have also had comments from people that the video moves oddly plus delay when playing X Box games, for example COD. Looking at wikipedia I would of thought that the interlacing of video and sound would be done by the receiver as both go through it.
I'm having problem with sound when I use my Pioneer Elite VSX-32 receiver. Everything is fine if I directly connect to my TV with HDMI cables from my cable box or my roku box. However, if I use the same...
check the audio output settings of your components. THey may be set for dolby digital which your receiver can process but your TV can not. Try PCM stereo setting or "other".
Apr 29, 2014 | Pioneer Audio Players & Recorders
Pioneer vsx 517, should the optical light be illuminated? Can't get sound from TV
yes" all optical lights are illuminated when the device puts out sound...
when its not lit it's an input.when it's lit it's an output
Nov 03, 2013 | Audio Players & Recorders
I have a pioneer vsx 517 receiver. The volume on the fm setting plays just fine but when switched to tv sat i have to turn the volume all the way up to hear anything. It work fine before. just trying to...
That would depend on where the (unidentified) TV audio comes FROM. If it's the analog output of the TV, the TV has a volume control hidden somwhere in a menu. Or you could select the FIXED output so its volume control has no effect on external use of the audio.
If the TV audio comes from a Cable Box analog output, IT might also have a control that varies the volume out. Disable it.
Jun 29, 2011 | Audio Players & Recorders
Hello, Problem is that after a few seconds the display shows "overload. " integrated circuits seem to be good, and I say this because I measured the voltage on each output amplifiers, and I have...
ALL the IC's are ok?
You'd measure 0 vdc if it was turned off, too, so that doesn't prove much.
Generally speaking, an amp protects itself from heat, shorts and overloads. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 01, 2011 | Pioneer VSX-517
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Nov 03, 2009 | Pioneer VSX-517
Vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Apr 20, 2009 | Pioneer VSX-517
I have a Pioneer VSX-D912. I just switched to HD Sat. When I hook into the component ports, I get no picture. When I use the DVD port I do get a picture.
I have exaclty the same problem. DVD into comp in 1, and my Homecast HT8000 into comp in 2 on my D912.
The dvd gets a picture.
The TV does not.
Looking at the settings I have "Component video Input" set correctly.
I'll add that when I do switch from DVD to TV, I get a scrabled vision of what is on TV for about half a second befoe the TV itself says "No, I can't display that" and gives me the blue screen of 'no signal'
Dec 29, 2008 | Pioneer VSX-D912 Receiver
Pioneer vsx-d814 will not power on after power surge
I pressed the front Enter and Advanced Surround for 2 seconds on my VSX-D814 and that worked. Thanks.
Mar 21, 2008 | Audio Players & Recorders
115 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
