Question about Echo Garden
I have an echo blower, I think it is a PB755 but the only identification i can find is P03-63B ( this may be the japanese model no) The crank is filling with petrol when not used for a while (to the point of hydraulic lock). this intrigues me as the carb is above the tank. I am thinking it must be the diaphragm but as yet I have not looked. If I am right where can i get spares
  • Jason Apr 05, 2011
    Are you located in the USA?
  • 577 Answers
Try changing your vent or check if it is plugged, it one of the 3 lines coming out of the tank(fuel)
it has a white plastic cap top usually tucked up by carb body, other thing is clean your carb and check your needle and seat making sure there is'nt a speck of dirt keeping the needle from sealing or shutting gas off when not running and the vent should keep pressure down in tank so it does'nt blow through the needle seat
Posted on Apr 07, 2011
Echo pb500t stallas when choke is opened
might check the exhaust port and muffler spark screen
Jul 19, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
Blower stalls when first cranking. Have to use choke lever to keep cranked until warmed up.
LOOKS LIKE THERE IS A PROBLEM WITH THE CARBURETOR OR THERE IS A CLOG IN THE SUPPLY LINE. IT JUST MIGHT REQUIRE SOME CLEANING AND FINE TUNING.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
My Echo PB-4600 lost a bearing on the crank shaft. The parts are available. Is this an easy fix or should I just thank the blower for its' 14 years of sevice. I bought the Echo PB775T to replace it.
WOW 14 years, I would give it a respectfull goodby. and spend $139.00 and keep going. The blower would have other "Age" related issuses even after you pulled all of the plastic off, removed carburetor,exaust and cylineder/head then you remove the flywheel and impeller then to split the crankcase and pull the crankshaft out replace the bearings. And all to reverse the steps wondering if you should have replaced the needle bearings and the wrist pin hopeing that the sealant you used on the crank case has sealed correctly, and are the piston rings really worn out or are they supposed to look like that. Then finally getting it all put back together only to find that it wont start because you dont have any spark or back firing because the coil is not adjusted correctly.
You have recieved GREAT service from that old blower. Good job.
Nov 10, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo leaf blower..cranks fine, idles fine, will not throttle up.
Sounds like restricted exaust. Remove the muffler and start it, see if that fixes it. If yes clean remaining carbon from exaust port. And clean spark arestor screen.
Nov 03, 2010 | Echo Gas Blower 135 MPH390 CFM Blower...
Plastic shredding plate on echo vac n shred model es2400 has worn out, where do I buy a new one?
I think you are describing the "fan" part of your blower. Go to www.partstree.com and input your model # and type #. The fan shows to still be available for about $12 plus shipping. To avoid shipping charges, find your local Echo dealer and get the part from them. www.echo-usa.com/dealers/ has a locator to find your nearest dealer.
Nov 03, 2010 | Garden
How can I download an operator's manual for an Echo power blower, Model PB-1000?
http://www.managemyhome.com/mmh/home?intcmp=MMHxG_HomexHome_Header
try this web site, they have a lot of manuals to download. found a manual for an old craftsman leaf blower there.
goodluck,
packrat101
Apr 19, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 | Echo Garden
Garden Logo
108 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
