Question about Titan Air Tools & Compressors
Need gasket at spray gun handle for tti lx-80
  • 2,428 Answers
You can get them at a paint store or you can make one i have serveral LX80s and i rebuld them all the time . If you have a build up of paint clean it with laquior thinner its a simple seal and it never wares out Ihave these guns that are 20 years old and the olny time i ever had a problem with this seal was when i used a torch to clean the gun before rebuilding it So keep it clean and you could use it every day and rebuild it every 5 years
Posted on Apr 06, 2011
If you're near Daytona Beach FL I'm a Daytona Beach House Painting Contractor & parts dealer.
Posted on Nov 25, 2012
Campbell Hausfeld HD4200 spray gun. Will not spray plain water. no siphon effect at feeder tube. What to check?
Check for air leaks above the top of the feeder tube. If it leaks air there, then no suction. Bad gaskets often cause this.
Oct 28, 2016 | Campbell Hausfeld Air Tools & Compressors
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
My graco xr5 sprays when i turn tip to spray position
If paint comes out of the spray gun after you release the handle, your problem is inside the gun. If the needle tip or seat are damaged or the spring that holds them closed is broken, paint will be able to get past the the needle and will come out of the gun even when the handle isn't held open. The stock spray gun that comes with the the XR5 doesn't have any servicable parts inside it so if it isn't working properly it may be garbage fodder. If you have an aftermarket gun, rebuild kits may be available.
Jun 13, 2012 | GRACO INC Magnum Xr5
My dad has a MBC-496-DEX and it is leaking air fluid beetween the nozzle and handle... Plzzz help ty!
rebuild and replace gaskets in gun ( call or email devilbiss for ins. or take to repair station.
Feb 13, 2011 | DeVilbiss Air Tools & Compressors
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Reaplaceing head gasket I need toruq specs for haed bolts. for 2002 2.4 12 v engean
the final torque setting is approx 80 foot/pounds incrementally if they are tty torque to yield bolts) Depending on the manufacturers of the replacement head bolts some require besides the obvious torque sequence followed either a TTY or a degree tightening after an initial sequence tightening while using the proper 30w , 10W-30 or manufacturers own mixture of molybelenum. Hope this helps.
Mar 06, 2010 | 2002 Toyota Camry
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Aug 12, 2009 | Porter Cable Gravity Feed Paint Sprayer
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Aug 27, 2008 | Grizzly H7670 Mini Hvlp Spray Gun,...
Air Tools & Compressors Logo
423 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
