Question about Gucci 21540 wristwatch
Need a new link for mens stainless stell wrist watch - 900M
SOURCE: Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Posted on Feb 16, 2008
SOURCE: tessot steel wrist watch band
i own a tissot too. instead of removing a link, just change which hole the link sits in on the clasp
Posted on Jul 13, 2008
indays
  • 111 Answers
SOURCE: Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Posted on Aug 28, 2008
SOURCE: my watch needs a new battery.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
Posted on Nov 28, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
How to change a battery
If watch expensive, take it to Shop to get it changed , if watch waterproof, it needs to be changed at a shop, as when battery changed , shop checks that the watch is still 100% waterproof.
Mar 07, 2015 | Tw Steel Grandeur Diver chronograph Quartz...
TX T3B891 INSTRUCTION MANUAL
Anyone know how to fit a new battery in a watch its a TX model number: T3B891
Jul 14, 2012 | TX Technoluxury 770 Fly-back Chronograph -...
Extra link 823a
This person wasn't asking for advice about buying a rubber wrist strap for a diving watch, but rather was asking about where to get an extra link for the watches stainless steel bracelet1
Jun 12, 2012 | Breitling Aeromarine Colt Auto / Colt...
Replace wittnauer wrist watch band
Looking for men's Wittnauer gold stainless watch band for JV 8243 Swiss 9544.
Please advise if you know where the are available.
Regards,
Steven Foxworth
sfoxworth1@comcast.net
Apr 10, 2012 | Wittnauer 10D02 Montserrat Watch for Men
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    Can't replace back on my Maurice Laroix stainless mens wrist watch. Do i need a special tool ?
    I went to Harbor Frieght and purchased a watch case press for $12.99 It worked perfectly.
    Dec 09, 2009 | Maurice Lacroix Masterpiece Regulateur...
    Lost the clasp for my kenneth cole reaction stainless stell watch
    I personally would take it to a jewerly and watch repair shop. If they don't have what it takes to fix it there they can get it. And they work on just about every thing
    Dec 16, 2008 | Kenneth Cole 3227 Wrist Watch
    Lost Manual for 98A001
    shadovitz Try www.bulova.com choose contact us, choose service centre, choose your watch from list (if not listed) choose a similar model/style
    Oct 30, 2008 | Bulova New! Wrist Marine Star Alarm...
    Gucci 21540 wristwatch Logo
    57 people viewed this question
    Top Gucci Watches Experts
    Lawrence Oravetz
    NOEL
    NOEL
    Are you a Gucci Watch Expert? Answer questions, earn points and help others
