How can i change the code from my powersafe TR 36 ELECTRONIC CODE? maybe i must press the red button inside ............? thanks,
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I Have a Hardline digital
a.
Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b.
If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c.
To change code repeat step a.
Test your new code before closing safe.
I had this exact same problem. Then I realized the red reset button was actually INSIDE the safe itself. So you need to enter the factory default code "159" to open the safe, then on the inside of the safe next to where the batteries are is a red button. If you press that, the yellow light will flash and you'll get two beeps. That means you can now enter your own combination. I hope this helps.
Posted on Oct 30, 2010
SOURCE: The batteries of my powersafe
I know this post is months old, maybe you didn't open your safe yet or maybe someone else could use the advice.
The batteries are no inside the safe because of this reason, that you should be able to change them if they run dry.
Under the key panel is a long plastic panel. You can slide it to the right and underneath you find the battery compartment.
4 x AA batteries
Posted on Apr 30, 2011
I have just change the batterys on my sandleford electronic safe ES23. now I can not put my same code back in. can u help me please. it has a key n a key pad as well.
Open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code, then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Jun 27, 2016 | Locks & Locksmithing
Tip
How to chanmge codes on most digital safes
To change the code on most digital safes. <br />you need to access the red button usually found inside the safe by the battery area. <br />Press the red button until you see two flashes. then enter your new code.<br /><br />PLEASE try the code BEFORE you close safe!! <br /><br />Thanks
on Apr 29, 2011 | Safe International Digital Electronic Safe...
Change code number to a new number on safe e.d.safe s25ebf
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Aug 04, 2011 | Office Equipment & Supplies
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
The batteries of my powersafe TR 36 are dead and I don't have any key. What can I do to open the safe? Urgent! Thank you in advance!
4 x AA batteries
Dec 30, 2010 | Safe International Digital Electronic Safe...
Where do i get instructions for changing the code on my hardline digital safe. The instruction paper that came with it appears to be for another safe. the paper mentions a red button where no red button...
-Mike
Jul 06, 2010 | Safe International Digital Electronic Safe...
Change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Nov 22, 2009 | Safe International Digital Electronic Safe...
I have a safewell electronic safe and no keys and lost code ex2007127402 can i have a code to over ride and open it
hi : about the stockwell safe ex200----- 2535-EA
if the safe still has charged batteries you can deactivate any sceurity code by access through a small hole on the rear of the safe, if you can get to the rear area of the safe.. You need a long screwdriver to reach to the inside of the front of the door . Their is a reset button on the inside of the door in the lower right corner area( "B" button) on the end - not on the flat face surface of the door but on the vertical face( hing plate). You'll have to feel around and push the screwdriver sideways to push the button in.it will beep . YAHOO- YUH DID IT !!!. Then you can reset your own code.if you need further instructions call me . icq. 33819110 or echarron1@cogeco.ca
Jul 26, 2009 | Locks & Locksmithing
Need to reset electronic safe
i have changed batteries and pressed the reset button but it still wont open any ideas thanks karen
Jul 22, 2009 | Kitchen Appliances - Others
Universal Remote Codes
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
Jun 11, 2008 | Philips PM435S Remote Control
355 people viewed this question
jasbo
jasbo
