Question about KitchenAid KSBP25FKSS Side by Side Refrigerator
I have a kitchenaid side-by-side KSBP25FKSS02. Sudden loss of cooling ability. Motor started sounding a little funny and seems to be running all the time -- so it's not that it doesn't "start." Bad compressor? We first noticed it in the freezer, then the next day the fridge, but maybe it was all happening at once. Any help appreciated. Thank you.
  • 1 more comment
  • David Talbot Apr 06, 2011
    Thanks for your reply. I have not yet received any advice or comment string on this yet. I am hoping to find out:
    1: Whether there is any obvious "simple fix" such as a fuse on the compressor
    2: Whether there is some other part (not the compressor) that is likely to blame on this model.
    3: If it's got to be the compressor, OK, I'll order it and replace it.
    4: The repair procedure for any of the above.
    Also, the icemaker is no longer working but I know it has water supply. If there is an obvious fix for this, let me know.
    Thanks.
  • David Talbot Apr 07, 2011
    Thanks for your note. Last night I restarted the fridge. I opened the panel and watched what was going on. The compressor seemed to kick on. Bottom line: the fridge is working again without my doing anything to it. Everythign was cold and frozen this morning in the freezer.
    Final questions:
    1: What do you think caused this? Is something failing? Should I replace something as a preventative measure?
    2: During the first 20 minutes of operation, the compressor got super-hot -- too hot to touch. But this morning, it was only warm, not super-hot. Is the fact that it got super-hot a concern, or is this normal when starting a warm fridge?
    Thanks
    Dave
    Macmarkus
    OK. The Kitchenaid manual said simply turning the fridge off and on can "reset" everything and solve a problem of loss of cooling. That may be what happened in my case. Having turned off the faulty fridge, I turned it back on last night and -- presto -- it's working.
    How do I blow compressed air through the condensor/coils? Where are those? And then I will drop the matter. ..
    Thanks again
    Dave
  • KitchenAid Master
  • 2,605 Answers
Hello, Welcome to FixYa. I can't seem to access any previous post dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 06, 2011
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Apr 06, 2011
    Hello again,
    Thank you for the reply. The place I'd start is to confirm the compressor is A) getting 120vac and B)operating...not just the fan beside it (condensor fan).
    If you have a multi-meter try this...Also, I don`t know the age of your fridge, but I should mention...
    ** Most of the manufacturers of fridges have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
    If you have a multi- meter you can check the compressor to see if the windings are ok.
    **First, Unplug the fridge**
    Remove the panel at the back down at the bottom. This should gain you access to the compressor.
    On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
    Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
    With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
    You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
    On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
    If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
    i.e.
    The above package contains info and hardware on how to connect it.
    NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
    Let me know if the compressor is indeed operating and I'll continue to help in any manner I can. Good luck
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 07, 2011
    Hello Dave,
    I'll address the first concern off the top. It is normal for the compressor to get quite hot upon start-up, especially on a warm system...the hotter the ambient temperature and the cabinet temp. the hotter the compressor will be since it has to work that much more.
    The second issue of the unit no apparently operating as normal, I would certainly keep a close watch on it. The scenario you described initially can be the result of several factors.
    1) dirty condensor or stalled fan motor. A good solution to a dirty condensor is blowing compressed air through the coils...although it can be messy unless the unit is wheeled outside, or secondly, vacuuming out the condensor...not as efficient but better than nothing.
    2) poor relay connection on the compressor, which gets worse with an increase in operating temp. ( as the compressor works more in hooter climates the relay can overheat and cause the overload to trip...hence the compressor will not cycle porperly )
    As I said keep a close eye on it's performance and keep me posted. If it acts up again I'd refer you to check the condensor, fan motor and compressor start device.
    Good luck. I'll watch for your future post if necessary.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 16, 2011
    Hello again,
    So sorry to not have replied sooner. Honestly I didn't even know you had replied since my last post. To clean the condensor, by blowing it out with compressed air.
    You'll need to slide the unit out away from the wall as I alluded to, remove the panel at the bottom in back, as well as the grill in the front bottom, then simply blow air from front to back through the coils and back to front...it's messy, but the best method.
    Hope the issue has been truely resolved and things are fine. Let me know either way and good luck.
    Regards,
    Macmarkus :)
Why does my fridge not cool,the fan doesn't kick on and the black little tank gets really hot?
A fridge operates due to adiabatics, which is the ability of a gas to absorb energy by compression, which turns to heat, then dispel heat by evaporation. The little black tank is a compressor which compresses the gas in the condensation loop. When the gas is compressed it heats up, so the little back tank will get hot, as will the condensation grid, often at the back of the fridge, which acts like a radiator to cool down the gas inside. When the gas is evaporated into the evaporation loop, it expands again and any rise in temperature caused by the compression will be lost. Add to this loss in temperature caused by the radiator and you have a total net loss in temperature which is significantly cooler than what you started with.
The problem with your fridge has to start with the fan not working as this fan will help to cool the condenser radiator, unless it is a fan inside the unit itself which just distributes the cool air. (without knowing the make an model of the fridge I cannot determine the reason for the fan). Modern low energy fridges have a better and more economical set-up and it seems that your fridge has seen better days. The compressor is clearly working overtime to get so hot and particularly if it never seems to shut down or the fridge cool down. Sadly, I think it's time for a new fridge. You'll save the money you are currently spending on the electricity to run the old one.
Sep 19, 2015 | Refrigerators
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Evap fan runs constantly
The fan should run when the compressor runs.
Nov 23, 2012 | KitchenAid Refrigerators
Kitchen Aide, model Ksbp25fkss02 is causing vegetable bin to freeze products
This sounds like you have a bad 2188820 Thermistor on your freezer vent. Either way it will take someone a little time to decide which side is controlling correctly (freezer or fresh food section cold controls) It may pay to find someone that don't mind a little time locating which one is causing the problem. Here is a PDF Service Manual go to page 16 and begin reading. I will be here later today to answer any questions you may have, Thank You, Sea Breeze
Ksbp25fkss00 Freezer Liner Parts
Feb 23, 2012 | KitchenAid Refrigerators
Freezer is defrosting pipes in freezer hanging funny and funny plastic smell coming from freeze
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | KitchenAid KSRS25IL Side by Side...
MY KITCHEN AID SIDE BY SIDE FRIDGE IS NOT COOLING. tHE COMPRESSOR IS HOT AND APPEARS TO BE RUNNING. Please help. Frank
1.The fan motor at the compressor must be running to keep the compressor cool.2. If you hear a clicking sound at the compressor,that is a indication of a bad compressor start relay that must be replaced.
Nov 11, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same time..is the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
Jun 11, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer is very cold and refrig is not
make sure the return air is open, that is a vent on the side wall of the refrigerator above the crispers on the center mullion. and check to see if the evaporator fan motor is running.
Jan 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all KitchenAid KSBP25FKSS Side by Side Refrigerator Questions
KitchenAid KSBP25FKSS Side by Side Refrigerator Logo
187 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
