The images on my computer screen shake back and forth making it difficult to read. I tried hooking up my screen to another computer and the images were fine. Some one suggested to me that it may be the video card. The computer is an emachine T6414. What should I do?
    Scholar:
  • 142 Answers
First step, Go into your Control Panel and find the Display settings. In the display settings there should be a tab to adjust the monitor. Try changing the Screen refresh rate. Also, make sure you have the latest drivers for your video card and operating system.
Posted on Apr 05, 2011
Read error appears after downloading pictures and looking back in the camera, some pictures have read error
When you hook your camera to your computer you are accessing it like a disk and changes made to "files" are saved to the disk. A common change is to rotate the image so it views correctly on the computer screen for images you turned the camera to take a portrait oriantation shot. That change is saved to the image on disk, then the camera can no longer display it because it is not the right "dimensions" for the camera (it is rotated)
Dec 13, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
Where is the outer tie rod on left side located
It is connected to the left steering knuckle (behind the left front wheel). Very difficult to see without removing the wheel.
Mar 06, 2011 | Chevrolet Lumina Cars & Trucks
The colors red blue shake back and forth on the ws55807 mitsubish
maybe you need to goto menu and auto converge colours..
try degauss feature if avail..
Is it a projection tv if so you may need a flyback anode block for R,B guns.
Dec 16, 2009 | Mitsubishi WS-55807 TV
I need to unlock the image on my computer, it was locked to protect my files. Windows simply does not show up on the screen not the start button? I am unable to start my computer! Windows XP, Compaq,...
Try to reset your in bios by entering setup in the startup. All you have to do is to press del or F2 botton some computer use F12 to inter bios setting.Or to remove your battery from the motherboard.
Nov 18, 2009 | Microsoft Windows XP Home Edition
Display shakes on monitor
Try these, 1) check the pins on the leads into monitor and computer thy tend to bend,
2) check there is no mains near the cables or monitor, it can cause feed back (EMF)
3) check the graphic card "if fitted " is not lose, unplug computer, then switch on comp without plug in socket, this will purge the board of any electicity, remove graphic card check for dust ect clean and then replace, put plug back in socket and switch on.
4) when a moniter is first switch on it purges the screen "degauses" "maybe spelt wrong" if it is constantly doing this it will be a fault within the screen.
5) Try a different cable that you know works it could be a break in the cable someware.
grandpaben
Aug 16, 2009 | Computers & Internet
Steering Wheel Shakes/Rotates back and forth ~ 1" - Shimmy's?
did you ever let somebody check the wheel allignment, it may be the camber shaft.
Feb 26, 2009 | 2002 Ford Expedition
LCD is not displaying
I am not familiar with this particular camera, but if there is any other form of viewfinder on it, there is probably a way to switch the picture back and forth from the LCD display to the viewfinder. Personally I would not buy a camera without a viewfinder, but right now, the only companies who make cameras with an optical viewfinder are Canon and Sony, and even they are getting away from it! Shame on them!
The other type of viewfinder that works well is the type that reads the CCR image onto a smaller screen to use as a viewfinder, like my Kodak Z712, or the Nikon P-80, I think it is, with the 18X Zoom.
One of my issues is that I like to take available light photos outdoors at night, and the LCD screen simply is not bright enough to show the image, even though the camera is able to make a decent photograph in that light.
Most cameras will let you shut the LCD screen off to save battery power, so you will have to find out what every button on the camera will do, and make sure that the screen is powered on. It may also be that you have to recharge or replace the battery in order to have enough power to turn the screen on.
Of course, as we say in the computer world, RTFM! Most of your questions will be covered in the manual, so read it from cover to cover, with the camera in front of you. I was a freelance photojournalist for two decades, and trust me, there are still things I won't know about a new camera without either reading the manual, or experimenting.
Feb 05, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Monitor screen shaking and flickering
Check to make sure the cables are connected tightly. Wiggle the cable, does it get better or worse? Might need a new cable. And reseat the video card inside the computer. If that doesn't fix it, then yes you will probably need a new monitor.
Jan 15, 2009 | Acer AL1917W LCD Monitor
Monitor problem - images are "shaky".
are you using the onboard graphics card? if yes try using a plug in card in the AGP slot to see if it makes a difference.It sounds like either an onboard graphics chip problem or a motherboard problem. come back to me for more emachine support, One of my specialised fields is in these computers.
Sep 15, 2008 | E-Machines eMachines Monitor E15T4
Rca scenium 52 inch replacement screen
I`ll have to be the bearer of bad news, the image is not burned onto the screen it is burned into all 3 of your picture tubes, which basically means the set is junk because the cost is too high.
Nov 29, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
