Question about Disney Princess: Enchanted Journey for Nintendo Wii
How do you get through the bell gate - Disney Princess: Enchanted Journey for Nintendo Wii
Why did my Lionel fast tracking crossing quit working the bell works but not the gates or flashers
these are real neet , there a combination of a few great items to all in one device , this device consists of two automatic crossing gates , one track automatic detector and of course a automated bell , well first thing to do is to look real careful at the track detector , these wont work if there under any stress or leaning (as this is the principle of there operation) so first see if track is twisted or leaning as it enters the device ? if all is good make sure that detector is not damaged or there isn't any foreign objects down inside it (for me its always those darn pine needles off the tree) , the reason the crossbucks don't light is that gates arnt moving , the switch for them is inside the motor housing that moves the gates
Mar 20, 2016 | Crafts & Hobbies
2002 Dakota. There used to be a bell for low fuel, check gates. The bell has stopped and now all the light in and on the vehicle blink. Any clues to what this is?
First thing to do is make sure the battery is charged. Then disconnect it for about 5 minutes and reconnect it. If that does not do the trick, the BCM (body control module) may be bad. This is several hundred dollars to replace.
Dec 21, 2015 | Cars & Trucks
My auto load won't work on my Bell and Howell 20XS won't work. How can I fix it?
I have the same problem, have you found a solution? Just started searching net for answer, will post back if I find something.
Jan 25, 2014 | Bell & Howell 20xc Dual 8 Projector...
Lift gate open warning light sounds when temp is below 60
sounds like the cold temps cause the metal door to warp which causes an increased distance to the sensor that tells the computer the lift gate is open. The lift gate sensors should be adjusted to be closer together.
Dec 12, 2013 | 2008 Jeep Grand Cherokee
Lift gate open
Has anyone suggested replacing the BCM (body control module)
I have a commax intercom (dp - 2hp model). There are two wires connected from the bell outside to the connectors 1 & 2 on the unit inside and the bell is working. There are another two wires connected to...
you just said where everything goes, so what's the question?
connector 5 goes to your gat actuator, 6 is power for the unit, obviously there will be 2 wires for each for a complete circuit.
Oct 04, 2013 | Radio Communications
I have a packard bell computer. an d there is no one usb gate that works
I dont believe that Packard Bell's ever came with USB ports on them. You can purchase a USB card and install it into your computer to give you access to USB devices. You can try looking for a USB card on either Ebay or try here www.geeks.com
I hope this helps you out, if it does please give me a YES that I did try to assist you. Thank you
Apr 09, 2011 | Packard Bell Computers & Internet
Waste gate jammed on torbo on 2002 passat
go to alldata.diy.com pay $20.00 to get detailed info on the trubo, most likey the hose is wore out the rubber hose and will have to be replaced the waste gate keeps from over boosting the engine so if the hose is worn the clamps won't hold it any more. remove the hoses on the turbo wiggle the turbo shaft back and forth and end to end there should be no play in the shaft if there is you need a turbo kit and can buy one to rebuild it, look up bell turbos in oregon on the net and get his number he can tell you the cost of the kit and how to rebuild. If you have excessive oil on the rubber hose then you have a blown oil seal and it will need to be replaced. you are lucky at this pont and the kit will come with what you need to fix the waste gate as well, but dought the gate is the problem.
May 24, 2009 | 2002 Volkswagen Passat
I am playing chronicles of narnia prince caspian ps3 game and after getting to mirazles castle i find it difficult for the past one week now to get past some particular guards please can i get some cheats...
Make sure to look to the right before you enter into either of the missions.
For this mission there is a stairway right before the opening that has chests.
Down the stairs use Trumpkin to go through the tunnel. Have him stand on the
glowing panel to open the gate for other players to get down. Then pull the
lever over to the left. Run back over to the right and turn the turn-wheel.
You'll notice a ring in the circle spinning until it is depressed. Go run over
to the lever and pull it and then back to the turn-wheel to depress a different
ring each time. Once you've done every ring the bottom right gate will open.
Go inside the area you just opened and open the chest. Now pull the nearby
lever. You'll unlock the area from before you went down the stairs. Go back up
to that area and open the visible chest. Now run over to the tower to the left
and climb up the rope. There is one more chest up the tower. Now you're good to
go!**
Once you've gone past the open gate you have to defeat a couple guards. Put
them down quickly and then destroy some barrels in the right corner. Find the
shiny item and put it in the shiny spot. Now instead of using the B button to
utilize the completed object, you'll be turning it by walking into it. Make
sure to push it clockwise to get it to move. Once you're done the bridge to the
right should be open for walking. Note: You might want to pick up that glowing
purple sword on the ground for the next part.
On the bridge use Caspian to shoot the arrow marker above the gate to open it.
Once beyond the gate guards will begin to ring bells. Theres one bell on top
and one below. Quickly run to the guard ringing the one on top and defeat him
while taking out anyone in your way, and then run to the bottom guard.
Hopefully none of the guards will replace the ones you just beat to ring the
bells.
Once the guards are defeated you'll need to run down to the bottom and destroy
random barrels and what not. There should be two glowing items: a lever part
and a turn-wheel. Put them in their respective locations on the second floor.
Pull the lever and then twist the wheel. The gate should open for you.
Once you head on across the bridge you'll go up a tower and face more guards
ringing bells. This time theres only one bell on the bottom floor. Quickly
locate the steps (this might be a little hard, they are somewhat hidden but
just keep on running around till you find 'em) and go down. Find the bell and
beat up any guard that tries to use it. Defeat every wave of guards until they
stop coming.
Once the guards are all defeated look for glowing platforms on the top floor.
Step on each. Now use Caspian to shoot arrows above the doors to open them.
There should be a turn-wheel and a large cog. Pick them up and put them into
their respective slots. Turn the turn-wheel and the lift will be activated. Go
up using the lift and use the lever to open up some door.
Now go look around the top floor until you find a spot to use your arrows.
You'll be taking this bridge down to cross. Once you shoot both arrows with
Caspian switch back to Peter to grappling hook the bridge. Pull it down and
cross it.
Once across you have another set of guards to put down. Go down to the lower
floor to take out any guard who wants to use the bell. Go up to the top floor
and scout around for a chest. After opening the chest look for some glowing
panels to step on, step on one with one of your characters and the other will
step on the other. This will conclude this objective.
Next is to defeat the sentries on the walls, but I'll let you have fun and take it from there.
Hope this will Fix Ya!
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
Lift gate latch of 2003 Ford Escape
I just want to know if there is any manual to disarm the lift gate and check for the problem. Currently my door is lock and cant open, how you force it to open?
Jun 19, 2008 | 2003 Ford Escape
Disney Princess: Enchanted Journey for Nintendo Wii Logo
62 people viewed this question
Top Disney Video Game Consoles & Games Experts
James Wishart
NOEL
NOEL
Bill Boyd
Are you a Disney Video Game Console and Game Expert? Answer questions, earn points and help others
