My drive is requesting to format itself and I have important files on here. How can I gain access again and also stop it from asking me to format it
    Scholar:
  • 44 Answers
Hi rfaber. Is it a desktop system that you have or is it a laptop? When you first turn on your computer, do you arrive at the desktop and then you start receiving this message that your hard drive needs to be formatted? It sounds like your hard drive may be bordering on faulty. Are you able to scan your hard drive for potential viruses? I would try and do this first if you are able to using your antivirus product.
Do you know how long you have been experiencing this problem? I'm thinking that you may be able to do a system restore just before the period that you experienced this problem, that's if it's software related, i.e. a virus on your hard drive.
Also, and this ins't in any way meant to sound accusatory but, could your pc accidentally have been dropped or bumped whilst the hard drive was running? If this was the case then it's likely that the disks may have been scratched and this could destroy the hard drive beyond use.
You say you have important data on your computer? You could try turning everything off and removing your hard drive from your system and connecting it externally to another computer and it will then act as an external hard drive but you would need a connector for this and this is known as an IDE to USB connector or adapter. It's a cable that has an IDE connector on one end which will connect to your hard drive and on the other end of the cable is a usb connector and this will connect to any usb port on a computer. The drive should then be recognised and you can hopefully access the drive and remove or take copies of your important date and place it on the working computer. Here's a link for this option:
http://www.usbnow.co.uk/Adapters_&_Connectors-USB_to_IDE_Adapters/c42_46/index.html?gclid=CP-rhKrbhagCFQEZ4QodhhBMiQ
If your hard drive is faulty then you may need to replace it and you will definitely have to try and retrieve your data using the above step. If you do this yourself make sure that you ground yourself before touching anything inside your pc and you can do this by touching a metal port on the rear of your computer if you don't have what's known as an ESD or ground bracelet. By doing this, this will release any static discharge from your fingers and then I will be safe to remove your hard drive.
I'm hoping that you don't have to do that though. Try everything you can on the desktop including disk checking for errors and possible recovery of bad sectors on the hard drive. Apologise for extensive information but I hope some of this information can be of assistance to you. Good luck. Andrew
Posted on Apr 05, 2011
My memory card is not opening
Your card may not be formatted -or- it is and it;s a proprietary format. If you want to format it, here is the instructions (for Windows):
Put your card into your computer (some have a slot or else use a card reader). Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Dec 21, 2011 | Kingston 2GB Secure Digital Memory Card
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
WD 10EADS external USB 1TB HDD. Using XP windows explorer, selecting drive returns a comment that it is not formatted. Using Windows98 explorer gives brief correct directory display but there are...
Sounds like you may have a corrupted drive or that the file catalogue on the drive is corrupted. Try accessing the drive on a different machine, if you can suspect the usb ports or the cable from the drive, if you still cannot gain access, the drive is corrupted. There are people who can extract the data off a corrupted drive but this is expensive so if you dont really need the data on the drive, reformat and start again..
Mar 17, 2010 | Computers & Internet
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
File system error
If you have a file system error, The only way to repair it is to format it. You need to have it connected to pc, then go to my computer, then to go F: drive or whatever drive the player is on, then you can access the files from there.
Aug 24, 2009 | Nextar MA933A MP3 Player
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
Vista wants me to format my external harddrive.
Can you access this drive on a non-Vista system? If so, try the Simple Tech WWW site for a diagnostics program?
There are also a number of other software programs that can detect and mark the bad sectors or locations on your drive as bad.
Once those sectors are marked (at the FAT Table) as bad Vista may allow you to access that drive again. IF it does, copy everything available to a DVD. Now reformat the drive but DON'T trust it.
Bottom line is that I personally would not trust that drive again with ANY data that is important to me... I hope you will agree with me. If you decide to use it anyway please backup to two locations or drives!
Good Luck!
Feb 22, 2009 | Western Digital My Book Essential Edition...
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Oct 07, 2008 | Sony Network Walkman NW-E105
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
